Engine Cut Out- couldn't restart
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=34441
Printed Date: November-17-2024 at 9:30am
Topic: Engine Cut Out- couldn't restart
Posted By: Ski-licious73
Subject: Engine Cut Out- couldn't restart
Date Posted: August-18-2014 at 8:29pm
Hello All,
After getting the electrical issues fixed on the 73 Ski Nautique, (again, thank you for the assistance) we ran the boat for the first time last weekend. Ran strong for about three hours then we docked and trailered her home . Dropped her in the water again today, ran strong at about 45 MPH for 15 minutes then seemed to bog down, and cut out. No real spits and sputters and it happened very quickly. Started up again and ran fairly strong back towards the dock. When approaching the dock and throttling down it cut out again...and wouldn't restart. Of course it was just in time for the thunder, lightening and torrential downpour to engulf us 75 yards from the dock. Was a long paddle in! Any suggestions on what to look at next? A friend mentioned the water separator? Thought I'd throw this out to the experts . Thanks in advance for your replies!
Posted By: Orlando76
Date Posted: August-18-2014 at 9:44pm
Lol, You mentioned T storms and downpours I thought, well you must be in FL, then I saw Daytona on your page.
I think I'd start looking into the ignition system first, mainly I'm guessing Coil?? Are you getting spark at the cylinders? Are you still running points or have you swapped to electronic?
Date Posted: August-18-2014 at 10:25pm
Last week a guy was down from St. Augustine going through the boat. He checked all cylinders and they all had good spark then. Boat has electronic ignition. Don't know much about the surrounding Mount Dora waters though I know it's not far from Daytona. Love to get her out of the salt and into some fresh water. Thanks for the reply! Your boat looks very similar to mine. the exterior anyway!
Date Posted: August-18-2014 at 10:47pm
Well one weekend boogy over to Harris chain, we are out every weekend and few week nights too dad brings his '75 often .... Except when I decide to go out of Ponce to shoot Grouper and lobster.
I would start by pulling a plug and visually look for spark while turning the engine over. Better yet is one of them handy dandy spark checkers that go inline with the spark wire and plug.
Posted By: JPASS
Date Posted: August-18-2014 at 10:54pm
http://www.summitracing.com/parts/lil-20610" rel="nofollow - Best $11 I ever spent
'92 Correctcraft Ski Nautique
Posted By: Tim D
Date Posted: August-18-2014 at 11:34pm
Running it that fast, that long, I would check to see if the timinig is set too high. It could over advance and die down.
Tim D
Date Posted: August-18-2014 at 11:45pm
We only ran fast for about 15 minutes or so. On the week before barely fast at all due to the no wake zones heading south on the inter-coastal towards Ponce Inlet from Daytona. Would that period of time do what you're referring to? Another question I have is how much water is normal to be in the bilge? I know that's a rookie question but I am wondering if I have water coming through the packing around the shaft. The hull looks great
Posted By: JPASS
Date Posted: August-18-2014 at 11:49pm
I usually get about a cup or so of water in ours after a day on the lake. Not very much at all. I've had the boat sitting in the water for an entire weekend and never had enough water to kick on the auto-bilge pump.
Date Posted: August-18-2014 at 11:53pm
I am definitely getting more than that. Is that something that I can readily fix myself?
Date Posted: August-19-2014 at 12:10am
looked on facebook and saw a video. think I can handle it ! Would guess that must be the source of the water I am getting.
Date Posted: August-19-2014 at 7:54am
Geez, I'd assume you didn't really run 45 for 15 minutes. I assumed peaked at 45 sometime in a :15 period. Take it easy on the old girl.
Posted By: Bri892001
Date Posted: August-19-2014 at 10:06am
Coil related on the original issue?
Posted By: mark c
Date Posted: August-19-2014 at 11:33am
How about the best 5 bucks you've ever spent.
http://www.harborfreight.com/inline-ignition-spark-checker-69014.html" rel="nofollow - in line spark checker
They have 90 degree versions as well for the same price, also noids for checking fuel injectors for you guys with FI boats. at 5 bucks a piece you could get 8 and have your own light show as the engine runs.
Posted By: craigslisthooker
Date Posted: September-18-2014 at 8:24pm
Did you ever get a response about the water in the bilge? I just got a 77 CC Fish Nautique. It's a beautiful boat. It sat for a couple of years before I got it. We has the shaft log replaced with a new DSS, but the bilge fills up a lot faster than we would like. I am not sure the source of the problem, but any advice on how to find it would be greatly appreciated!
dan-ger
Posted By: Gary S
Date Posted: September-18-2014 at 10:02pm
Not too many places for it to come in as you know Dan. Rudder port,intake thru hull, shaft seal bad from sitting and leaking,unless you just put it in, thru hull transducer if you have one. You could possibly have the boat on the trailer and fill it with water and see where it leaks out.
Date Posted: September-19-2014 at 1:09pm
Great advice, thank you. I will pull the boat next week and fill the hull. I have a feeling, it is coming from the rudder. The DSS shaft seal is brand new. I will need to figure out how to repair/repack the rudder. Thank you!
dan-ger
