Sun deck actuator
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=34574
Printed Date: November-17-2024 at 3:49am
Topic: Sun deck actuator
Posted By: KileyB
Subject: Sun deck actuator
Date Posted: September-06-2014 at 1:34am
I can only get my sun deck actuator on my 92 Excel to go down once in a while. I've opened up the dash where to switch is. If iI give power to the load side of the switch it goes down every time. Replace the switch you might say? Did that....same issue. Any thoughts?
'92 Excel
Posted By: boardersdad
Date Posted: September-06-2014 at 3:33am
It sounds like you are applying 12V from a different circuit. Have you tried just using a short test wire with alligator clips to jump across (skip) the switch? That should show you if something in the circuit prior to the switch is causing the problem.
Posted By: Bri892001
Date Posted: September-06-2014 at 4:12am
Use a voltmeter (multimeter set to test 12 volts) to see what kind of voltage you are getting to the input side of the switch.
It could be a low voltage problem.
Posted By: KileyB
Date Posted: September-06-2014 at 12:56pm
Thank you. Will give that a shot.
'92 Excel
Posted By: Air206
Date Posted: September-06-2014 at 1:30pm
92 was the first year of the actuator. They had problems from the start. Wiring to the actuator motor was too small and many suffered early on. To help, add a relay and a heavy gauge wire to the actuator from the battery....similar to a horn circuit.
Newer actuator motors and heavier gauge wires made them more reliable.
https://tinyurl.com/y6t5e3bu" rel="nofollow - 04 Air206
http://tinyurl.com/9urzgls" rel="nofollow - 91 Barefoot
78 SkiTiq
Posted By: KileyB
Date Posted: June-27-2015 at 4:03pm
I have determined that it was a switch under the sun deck that got gooped up from the rubber stop disentigrating. The "stop switch" cuts power so the actuator doesn't pull the screws out of the sun deck. The rubber stopper was melting into the switch causing it to stick occasionally.
So in the process I messed with the dtdp switch at the helm and can't remember how exactly the wiring is supposed to go. There is a blue interrupt wire to cut power when the sun deck is all the way down. Two ground wires. A constant hot and two orange wires that appear to send power to the actuator to tell it to go up or down.
does anyone have the correct wiring for the dash switch?
'92 Excel
