What kind of paint to use?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=346
Printed Date: April-26-2025 at 12:28am
Topic: What kind of paint to use?
Posted By: veedub88
Subject: What kind of paint to use?
Date Posted: May-03-2004 at 6:26pm
I have read through the posts and haven't found an answer. I have a 1977 martinique and the paint from the water line down is chipping off- possibly wrong paint type or bad prep job? I have to paint it because there is already a barrier coat on the boat and I'm not going to sand all the way through that for new gelcoat. There are so many different paints (ablatives, epoxys, antifoulings) My boat is trailered many times a summer and its sometimes stays in the water for several weeks. The guy at west marine said to use a copolymer ablative but I don't buy that because it wears away after a couple of years and I want It to last at least 5-10 years. I don't think I need an antifouling paint because the boat isn't in the water extended periods and the water is clean. Would a hard epoxy based paint work like the VC performance at west marine? So does anyone know what kind of paint to use?
Posted By: 79nautique
Date Posted: May-03-2004 at 6:38pm
Most likely what is on it is bottom paint i.e. antifouling paint that will ware off over time. The boat was not bottom painted from the factory so anything that is on there is a best guess and getting something to last for your time frame is slim and none. Unless you leave the boat in the water all season there really isn't a need. Good luck in finding something to your liking.
Posted By: boatnut
Date Posted: May-03-2004 at 7:33pm
If you have 'anti-fouling paint ' of any kind on it now, you will have to sand it off for other paints to stick. If you aren't going to use anti fouling, any paint recommended for "use below the waterline" will work. Two part copolymers are long lasting paints too. But preparation of the surface is 90% of the battle.
Posted By: cisom
Date Posted: June-10-2004 at 8:52pm
There isn't a bottom paint made that will last 5-10 years. There are "high speed" bottom paints that are not ablative. I believe they are very slick and the speed of the boat scrubs off any marine growth. No matter what you end up doing you're going to have to sand. At least it's not a 30' sailboat hull, that's no fun.
Posted By: kenny g
Date Posted: June-10-2004 at 11:22pm
my opinion only.you can use the best product known to man,but if you apply it over s*#@,thats what you'll end up with.this process can be quite an investment,time and $.if the paint on the hull is chipping off,it's obvious it aint stuck.so whatever you apply over that "barrier" coat wont have a chance. lot's of good products on the market today,and they all claim to be the best.proper surface prep is the key.
kenny g
Posted By: Guests
Date Posted: March-27-2005 at 6:51pm
kenny is exactly right. prepping the surface is everything.paint needs a good place to stick and if not prepped correctly it wont. i would smoothe out the surface,finish it out with 220 grit,primer it, finish that with 400 grit, then seal it and paint it with imron paint.hey,if it works for bulldozers and tractors, i think it would work fine for a boat. if not, use ppg concept. it is a single stage urethane, and it worked wonders on my 83 ski nautique.
