tachometer died on 93 ski nautique
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=349
Printed Date: January-30-2025 at 11:50am
Topic: tachometer died on 93 ski nautique
Posted By: rstevenson
Subject: tachometer died on 93 ski nautique
Date Posted: May-04-2004 at 3:19pm
I have a 93 closed bow ski nautique. The tachometer seems to have died on me. It is a VDO guage with a white face and black bezel. I don't know the exact size (and the boat is not local) gauge I need or the exact guage. Looking on egauges.com it looks like the VDO cockpit white series, but I don't know for sure. If so, is it 3 1/8 or 3 3/8? How do I know if I need to replace the sender as well? Is it easy to do it yourself? Thanks for the help........
Posted By: yellowdog
Date Posted: May-10-2004 at 11:41pm
Are you sure the gauge has gone south? Not much in a tach to go bad. Check for loose connections or a bad wire. Is there continuity between the distributor and the tach? Tachs do not have a sender per se, they pick up the firing pulse from the positive lead off the distributor, usually a gray wire.
Seriously doubt if VDO still markets that tach. Most of the gauge outfits change their lines every few years because the boat manufacturers need variety in the lines to attract new customers. Contact them directly through their website.
As for replacing a tach, hardest part is crawling under the dash to get to the back of the unit.
------------- Caretaker of the wife's '78 Ski Nautique
Posted By: 882001
Date Posted: May-11-2004 at 1:50am
yeah they still make the tach. pt#1809 at skidim. its 89.90. but i was thinking it is probably a wiring problem. im sure reidp and 79 will dispute this info. screw em
------------- kemah texas
http://www.correctcraftfan.com/diaries/details.asp?ID=163&yrstart=1986&yrend=1990 - 1988
skinautique "2001"
Posted By: trauski
Date Posted: July-13-2004 at 8:12pm
93 nautiques are notorious for bad fuel gauges and spiking temp gauges. both of mine are bad. so it could be the tack but check for wiring. check the whole series as the gauges are intertwined with each other on the back. might be a good time to justify perfect pass as you get a digital tack read out that is much more accurate than the vdo. check with ski dealers , they take a bunch of perfect pass out of boats traded in and sell seperate for maybe 500.00 $
------------- 1993 ski nautique,pro-boss,14/16 OJ 4-blade,perfect-pass,dual mirrors on top
