Flush Pro by Perko
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=34958
Printed Date: November-17-2024 at 9:21am
Topic: Flush Pro by Perko
Posted By: Jonny Quest
Subject: Flush Pro by Perko
Date Posted: November-14-2014 at 3:14am
Anybody have any experience with the Perko Flush Pro?
http://www.perko.com/catalog/category/underwater_hardware/product/62/" rel="nofollow - Link
Looks like a nice addition and easier to use than the Fake-A-Lake or 5 gallon bucket job...
Posted By: JPASS
Date Posted: November-14-2014 at 8:40am
I have one of these attached to the transom and it makes it super easy to flush the motor.
$55 from http://christinesmarine.com/Exterior_Parts___Accessories.html" rel="nofollow - Christines
Posted By: baitkiller
Date Posted: November-14-2014 at 8:45am
$90 is steep for what they are. Most peeps here shop make one for a $20 trip top the hardware store. I use a T fitting made by Mercruiser for $3.80, a length of heater hose and brass garden hose repair fitting with a simple PVC plug. If I forget the plug, I fry an impeller. That is where the flush pro shines. But to answer your question, they work really well and are on many boats as factory options. One thought is that you may have issue regarding the 1" hose on a Nautique. I think these only come in 1.25" as that has become standard.Too lazy to check.
------------- Jesus was a bare-footer.............
Posted By: td_in_nc
Date Posted: November-14-2014 at 8:50am
I have one that came on the boat when I bought it. I took it off as I am in fresh water. If you are interested let me know.
Really can't speak to how good these systems are.
Posted By: td_in_nc
Date Posted: November-14-2014 at 8:56am
baitkiller wrote:
One thought is that you may have issue regarding the 1" hose on a Nautique. I think these only come in 1.25" as that has become standard.Too lazy to check. |
Good point. I just checked and the hose connection is 1 1/4".
Date Posted: November-14-2014 at 9:10am
I have seen reports that the Flush Pros break.
Posted By: lewy2001
Date Posted: November-14-2014 at 9:24am
The TRBerko is a much nicer setup and cheaper
Posted By: Orlando76
Date Posted: November-14-2014 at 9:33am
If I follow y'all correctly it could be either 1" or buck n quarter. Our one boat is 1", the other boat is larger. I must be doing the bucket method wrong bc it takes me one 3/8 but driver and :25 seconds to hook up.
Posted By: quinner
Date Posted: November-14-2014 at 9:49am
8122pbrainard wrote:
I have seen reports that the Flush Pros break. |
I have one that is at least 15 years old, managed to defy the odds to this point, lol.
When mine does fail however, which apparently is only a matter of time, a TimmyTee would be used as a replacement.
Posted By: Gary S
Date Posted: November-14-2014 at 10:00am
The TimmyTee. I was able to get everything but the T at Lowes
Posted By: Air206
Date Posted: November-14-2014 at 10:15am
Ditto - Used in multiple boats since 93...no issues/failures. Never paid anywhere near $100.00....
------------- https://tinyurl.com/y6t5e3bu" rel="nofollow - 04 Air206 http://tinyurl.com/9urzgls" rel="nofollow - 91 Barefoot 78 SkiTiq
Posted By: Donald80SN
Date Posted: November-14-2014 at 11:47am
I purchased one six years ago and I like it. So far no issues. I installed it before I knew about the TimmyTee or the TimBob, JimBob or KimBob thing. Much easier than a Fake Lake.
Posted By: td_in_nc
Date Posted: November-14-2014 at 1:43pm
| I was looking at doing this for running the boat in the driveway, but I was concerned that water could flow out the water intake. I guess it is not an issue.?
Date Posted: November-14-2014 at 2:02pm
It does. Non issue.
I should start charging royalties.
Posted By: Gary S
Date Posted: November-14-2014 at 2:05pm
You should,but now you have to cut Quinner in for the name
Posted By: Hollywood
Date Posted: November-14-2014 at 2:10pm
I have only heard of 1 person having trouble with the TimTee. His RWP suction was not enough to overcome hose water from preferring to fall out the intake. It was a v-drive Python. I don't know the orientation of T or the hoses.
The beauty of the TimTee is that you can hook up the hose and turn it on and you won't pressurize the cooling system with the engine off. The problem with other systems is that people forget to turn the hose on after starting the engine. Here you can let it run all day and it won't hurt anything, water will just fall out the intake. Crank the engine and the RWP will suck up the hose water. HOWEVER, you should give consideration to where the T is installed so hose water will naturally gravitate downhill towards the RWP first, back fill the rest of the hoses, and lastly, fall out the bottom of the hull. Find the highest point of your intake hose and go downhill a bit towards the RWP if you can. Don't install it right off the hull pickup, it might work OK most of the time but you're just making it unnecessarily hard on the RWP.
Posted By: quinner
Date Posted: November-14-2014 at 2:29pm
Well we all knew TeeTimmy was not without many shortcomings.
To HW's point, if equipped, close the valve at the hull pickup just before opening Timmy's gate and firing motor, should ensure water will flow in the desired direction.
Anybody know what year the valve just after the hull raw water pickup became a Correct Craft standard feature??
Posted By: Gary S
Date Posted: November-14-2014 at 2:37pm
Good points but I have put mine before the strainer and it does work.When connecting up you can see the flow thru the strainer and it filling. The quick connector speeds up the connection too.
Date Posted: November-14-2014 at 4:20pm
Well Gary, if yours works I can't see why it wouldn't work anywhere on the suction side.
DO NOT CLOSE THE HULL SHUT OFF! The only time you should close that valve is to prevent sinking. Those who close that for winterization inevitably forget to open it in spring and fry an impeller at best, an engine at worst.
The whole point of the T is simplicity. Hook up the hose, turn the water on, then go about your business. Don't complicate the process.
Date Posted: November-14-2014 at 9:51pm
That's why I love this site. Off to the Home Depot to buy the DIY "Timmy T"
Thanks for the help.
