Motor shuts off after a 45 min ride
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=3522
Printed Date: November-23-2024 at 10:27am
Topic: Motor shuts off after a 45 min ride
Posted By: Siveck
Subject: Motor shuts off after a 45 min ride
Date Posted: May-07-2006 at 12:23am
I can't figure this out. I have had this problem ever since I bought the boat two years ago. Everything is fine until after about 45 minutes of cruising. The motor will sputter a bit for about ten seconds, and then shut off suddenly. It will not run until it cools for about ten minutes. And then it does the same thing every 5 minutes until you let the motor completely cool off. I have rebuilt the carb twice, replaced the entire ignition system with an HEI unit, and alot of other stuff including a new fuel pump. My best theory right now is that the carbureutor is getting too hot as the fuel bowls do become very warm with the engine heat. Maybe the fuel is boiling or something? Vapor lock in the fuel line? Has anyone else had this issue. It happens consistently every time I go to the lake. Maybe I need a heat isolator of some sort for the carbureutor or a vent near the top of the motor box to let some heat out? The motor water temperature is around 160 degrees. Would putting a vent on the motor box mess up the bilge vent system? Any ideas or input would be great. Thanks
1975 Ski Nautique
"Small Letter Boat"
Posted By: jimbo
Date Posted: May-07-2006 at 1:34am
I have an 84 SN and I was having a somewhat similar problem recently. It turned out to be gunk in the fuel pick up tube in the tank. I pulled the tube, spray carb cleaner throught and it came out brown. Took it apart and the cone screen in the tube had a bunch of crap stuck in it.
Relative easy and worth a shot.
Posted By: 64 Skier
Date Posted: May-08-2006 at 1:41am
New Coil?
64 Skier
66" HO VTX and 67" HO Triumph
http://www.correctcraftfan.com/diaries/details.asp?ID=1071&sort=&pagenum=3&yrstart=1971&yrend=1975 - 71CC
Posted By: David F
Date Posted: May-08-2006 at 10:54am
Could be ballast resistor. Classic symptom...
Best way to test is next time the engine quits, be prepared (with onboard tools) to move all wires (at the ballast resistor) to one of the two terminals. If the engine then starts and runs fine, you leave it this way for the rest of the outing, but be sure to change it out before the next outing to avoid burning the points or module.
Posted By: Tim D
Date Posted: May-08-2006 at 1:27pm
Check the timing.
Tim D
Posted By: nuttyskier2002
Date Posted: May-08-2006 at 2:01pm
Did you install the HEI ignition before or after this problem started to occur? If before, is there any change at all with the occurance of this problem? With the HEI you should have gotten rid of the ballast that David F mentioned. However, he does suggest testing for spark when you have this problem which is exactly what you should do. Be ready for when the engine acts up,...when it quits completely disconnect one of your plug wires and insert a small bolt or something into the plug end boot. Fix this end so that it's about 1 inch away from ground. HEI systems are very strong and should have no problem at all firing across this gap. Crank the engine over and you should get spark accompanied by a very audible snapping sound. If not, start looking at your ignition again. If the distributor is known good, follow the ignition wire to the distributor back from the switch and see if it has good continutiy. Check the terminals on your ignition switch. Over time the wires vibrate and copper strands start to brake. Before you know it wires are just hanging on with a single stand. If you get to this point and everything looks good, write back and we'll go from there.
Former boats:
88 Ski Centurion Tru Trac II
59 Chris Craft Capri (woody)
Posted By: jimbo
Date Posted: May-08-2006 at 2:04pm
Edited...I just asked the same things as nutty lol
Posted By: Siveck
Date Posted: May-08-2006 at 9:42pm
Thanks everyone for the replies. The problem that I'm having is exactly the same as before the change to the HEI setup. And I don't have a ballast resistor anymore. The HEI came with a new coil. Could the timing affect something like this? The way that it just dies doesn't seem to be timing related. It definitely seems like like a heat issue within the engine cover area. It would probably be a good idea to clean out the pickup tube in the tank, but the problem seems to be too consistent like clockwork. Checking for spark next time is a good idea. Maybe I could use a timing light to check for spark? It may be a while before I get back to the lake as it is an hour from my house. The boat is in my basement where I can work on it at least. I hope that the above answers some questions and please keep the feeback and theories coming. Thanks Again everyone.
1975 Ski Nautique
"Small Letter Boat"
Posted By: Siveck
Date Posted: May-17-2006 at 11:54pm
I am in the process of replacing my fuel line between the tank and pump as well as cleaing out the fittings. There was no check ball in the fitting on the tank. How is the pickup tube removed?
Also, I have another theoury about this heat issue. Could the heat cause my choke mechanism to heat up and close the choke flap?
1975 Ski Nautique
"Small Letter Boat"
Posted By: David F
Date Posted: May-18-2006 at 8:54am
I would say no to your choke idea. The heat does the exact opposite to the choke, it opens it.
Posted By: jimbo
Date Posted: May-18-2006 at 12:00pm
On mine, I removed the hose from the tank and removed that fitting from the 90 degree fitting. I then unscrewed the 90 from the tank. You'll need to unbolt the tank and move it forward.
Put the 90 in a vise and gentely grip the tube with vise-grips or channel-locks and turn. Becareful not to smash the tube.
Posted By: Siveck
Date Posted: May-19-2006 at 12:06am
My choke is the electic choke and the heat rise is not connected. Some of the choke parts are actually missing. The electical parts are there along with a connecting rod and the plate. I never use the choke, I may remove it anyway for better airflow. One less thing to go wrong.
I have removed the 90 deg fitting from the tank and the tube is still at the bottom of the hole. Maybe I can unbolt the sending unit, reach in, and push the tube up from inside the tank?
1975 Ski Nautique
"Small Letter Boat"
Posted By: jimbo
Date Posted: May-19-2006 at 11:23am
That sounds like a good solution. On mine, the tube was screwed into a fitting. If the tube rattled loose somehow, that could be part of the problem.
Posted By: Siveck
Date Posted: May-22-2006 at 12:26am
I did some work on the boat and it seems to run without shutting down. The pickup tube in the tank was actually welded in (aluminum tank). I removed the float and reached to find this. The piecs in the top of that tube is some sort of creen or something that I couldn't see or remove. I sprayed carb cleaner in the tube about 20 times to clean the gunk out. Yeah I know it went into the fuel, but at least the tube is clean. I also cleaned the fittings and replaced the fuel line from the tank to the pump. I also replaced the fuel filter and removed the choke plate as I rarely use the choke. Now it runs without breaking down. Hopefully it will become a reliable boat and not break down every time I go to the lake.
1975 Ski Nautique
"Small Letter Boat"
