Floor Replacement
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=35269
Printed Date: November-17-2024 at 9:38am
Topic: Floor Replacement
Posted By: hdfooter
Subject: Floor Replacement
Date Posted: January-12-2015 at 11:47pm
Need to replace the floor in my 91' BFN V-Drive. I have a couple soft spots, mainly under driver seat. I installed a sub-floor over the top to get me through the past 2 seasons, but it's time to fix it correctly. Can I just run a circular saw around the periphery of the interior and replace the wood and fiberglass shell on top of the wood or am I thinking way outside the box? Any help and/or advise would be greatly appreciated.
Shawn
Posted By: storm34
Date Posted: January-13-2015 at 12:01am
That's the place to start but I would strongly urge you investigate other areas to assess the amounts of rot.
Posted By: hdfooter
Date Posted: January-13-2015 at 12:20am
The only other place I have seen any rotting wood is at the edge of the opening around the gas tank and trans cover. It's just a small spot at the corner, it's not weak, no flexing, just a little "Tired". She's an old boat and needs a little TLC.
Thanks, Shawn
Posted By: storm34
Date Posted: January-13-2015 at 1:09am
I'd be worried about the rotting wood you can't see. Open it up and dig out as much foam as you can and check for water. Ideally you could get a sample of the wood below soft spots.
Posted By: hdfooter
Date Posted: January-13-2015 at 1:24am
Thanks for your input. Hoping to start this project in the next couple week. I want enough time to get it repaired before it's time to get her back on the water!
Date Posted: January-13-2015 at 2:37am
Shawn,
Don't assume all that's needed is the sole replacement until you THOROUGHLY investigate ALL the wood beneath it.
Posted By: hdfooter
Date Posted: January-13-2015 at 2:44am
That's my plan for sure to make sure that all wood is in great to perfect condition. I'm more nervous about cutting the floor out and messing something else up. Do you know the best way to get original floor out? Is a circular saw the way to go? Setting the depth just deep enough to poke through existing floor!
Date Posted: January-13-2015 at 8:49am
I suggest going to the FAQ's and reading some of the threads on stinger replacement. Members have used several sawing methods. A circular saw is one of them but also using a inexpensive diamond blade on a right angle grinder is another.
I have a feeling you will be surprised what you find. Don't be discouraged and just keep moving forward. Read up on checking for rot and if you do find any, I suggest replacing all the wood and not trying to scab in a repair. Rot is similar to cancer. The spores are already in the wood waiting for the next time the proper moisture conditions are there. IE: even if the wood seems sound, it most likely isn't.
Posted By: hotboat
Date Posted: January-13-2015 at 11:24am
I don't believe anyone has had one of these opened up yet on here, get pictures so we can all learn please.
Brian
Posted By: phatsat67
Date Posted: January-13-2015 at 11:37am
Seems as if the V drive footers hold out for a while as far as rot goes. Mark's 91 sat outside FOREEEVERR uncovered. Given it only has like 500 hours on it but it is solid as a rock.
Posted By: hdfooter
Date Posted: January-13-2015 at 2:38pm
Mine only has 720 hours. My wife believes she remembers a story about a guy falling into the boat in his drunken stuper and that is what caused the weak floor, ie cracked floor. I will post pics as I go to help out. Thank you all for your comments. Keep them coming if you have anything to add. Hoping to learn as much as possible to not get myself into a pickle. Zac, can you get me a quote on putting in a hotfoot? I'll bring the boat to you guys. Looking for cost and timing please.
Date Posted: January-13-2015 at 2:51pm
You mean like Mark's boat with the hydrogate?
Posted By: hdfooter
Date Posted: January-13-2015 at 2:58pm
Exactly like Mark has, foot control and all.
Date Posted: January-13-2015 at 3:03pm
Cool Shawn. Steve had a good time coming down for the Christmas party. You need to get down here sometime as well.
I will pull up some numbers if you have any other requests email me and I will make sure they find their way onto an estimate.
Posted By: hdfooter
Date Posted: January-13-2015 at 3:55pm
Zachary, how about a new windshield as well. Mine blew out on the way home from the Lockwood River Roar last year!
