windshield screws
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=35472
Printed Date: November-17-2024 at 7:25am
Topic: windshield screws
Posted By: 75 Tique
Subject: windshield screws
Date Posted: March-01-2015 at 6:46pm
Looking for what I believe are called T-bolts to hold down my windshield. As you can see, mine are a bit tired.
Closest thing I could find are these at Mcmaster, but they are not an exact match.
Anyone help me out?
Date Posted: March-01-2015 at 6:55pm
Larry, There's some on http://www.ebay.com/itm/T-BOLT-BOAT-WINDSHIELD-MARINE-HOLD-DOWNS-SET-OF-36-BOLTS-DIRECT-REPLACEMENT-/271784316333" rel="nofollow - ebay
Posted By: Orlando76
Date Posted: March-01-2015 at 7:01pm
My wife said today she's tired of hearing the windshield rattle on a cold idle. She's right, wasn't there 2 months ago. I'm guessing these go inside the track so I'd have to pull the glass out? Is there a source for the rubber?
Date Posted: March-01-2015 at 7:07pm
Orlando76 wrote:
My wife said today she's tired of hearing the windshield rattle on a cold idle. She's right, wasn't there 2 months ago. | Check the screws that tighten the front to the sides. If your's doesn't have them, drill cleance holes in the female section and tap the male portion of the extrusion. Then tightening the machine screw will eliminate the rattle.
Orlando76 wrote:
I'm guessing these go inside the track so I'd have to pull the glass out? Is there a source for the rubber? | No, the T bolts and glass have separate slots in the extrusion.
Date Posted: March-01-2015 at 7:23pm
You kinda lost me here. Where it's rattling at is the center top where the two screws join the drivers side and passengers side together. I know those screws are tight. I just assume it's the t bolts bc they look pretty rough and are half gone.
Posted By: 75 Tique
Date Posted: March-01-2015 at 7:31pm
Thanks Pete....but I wonder if he'll sell me two. Hate to drop $30 for 2 screws.
No, the T bolts and glass have separate slots in the extrusion. |
EDIT: Ooops. Todd posted when I was composing. No longer relevant.
Posted By: Toertel
Date Posted: March-01-2015 at 7:39pm
man, the title of this post got me all exited and I was ready to chime in, but then it turned out its just another technical post.... anyway, on one side of the walk through is all loose screw and the screw does't bite anymore. shoul I drill a new one close by ( on either side) or try to fix the hole?
------------- 1994 Sport Nautique
Orlando76 wrote:
You kinda lost me here. Where it's rattling at is the center top where the two screws join the drivers side and passengers side together. I know those screws are tight. I just assume it's the t bolts bc they look pretty rough and are half gone. | Do the same at the center joint. Tight? I'll bet they made a short cut and didn't drill a clearance hole and just ran a type A sheet metal screw through both extrusion sections.
Date Posted: March-01-2015 at 7:43pm
75 Tique wrote:
Thanks Pete....but I wonder if he'll sell me two. Hate to drop $30 for 2 screws. | Larry, There's an older thread where one of our members evidently bought the $30.00 and was giving away the extras. I ran across it doing a search. I'll see if I can find it again. It was a google search.
Date Posted: March-01-2015 at 7:44pm
How many T bolts total are there?
Date Posted: March-01-2015 at 7:48pm
Toertel wrote:
on one side of the walk through is all loose screw and the screw does't bite anymore. shoul I drill a new one close by ( on either side) or try to fix the hole? | Sebastian, I'd first see what size screw they used and try to use the existing hole and tapping to the next larger size. Sheet metal screws used with the vibration and corrosion eventually wear out.
Date Posted: March-01-2015 at 7:56pm
Orlando76 wrote:
How many T bolts total are there? | Typically 8. Todd, Get under there and count!! Some may be under the foam.
Date Posted: March-01-2015 at 11:19pm
Larry, the eBay guy will accept an offer of ~$15, at least he used to. Be sure to replace all of the bolts and not just a select few, any original screw at this point is on borrowed time. SS is a nice upgrade.
Date Posted: March-01-2015 at 11:22pm
I was gonna suggest I'd split the bolts with Larry if he found no alternative. No sense on buying 36 when 2 is needed.
Posted By: Hollywood
Date Posted: March-01-2015 at 11:43pm
coach'80 did his windshield and was giving away the extras. See if he has any left.
