waves pushing water
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=3569
Printed Date: November-23-2024 at 1:15pm
Topic: waves pushing water
Posted By: HOLESHOT
Subject: waves pushing water
Date Posted: May-15-2006 at 1:01am
do you guys have an opinion on waves pushing water up the exhaust and in to the engine ?
------------- IF IT HAS A SPARKPLUG I CAN FIX IT
Posted By: nuttyskier2002
Date Posted: May-15-2006 at 6:31am
Does your exhaust outlets have flaps on them? These act as one way check valves that limit the water trying to rush into the exhaust pipe. Also the risers (if your exhaust is equipped with them) help prevent this from happening as well. A third thing is the camshaft. Marine cams are ground with less overlap (time when intake and exhaust valves are both open) but this only comes into play when th engine is running.
------------- 95 Malibu Echelon w/Mercruiser 350 Magnum Skier
Former boats:
88 Ski Centurion Tru Trac II
59 Chris Craft Capri (woody)
Posted By: Munday
Date Posted: May-15-2006 at 5:17pm
Man its sure no fun if it does happen.Make sure it doesn't by any means possible.I've seen it and if your short on tools it can ruin a boating.
good luck Munday
Posted By: GottaSki
Date Posted: May-15-2006 at 6:42pm
Seems like ther are plenty of tools around every time we go skiing...
River Rat to Mole
Posted By: HOLESHOT
Date Posted: May-15-2006 at 8:25pm
well im not saying that it has happened to me i was just wondering what ppl thought about the idea i dont think its likly but maybe possible
so please guys give ur two cents
Posted By: David F
Date Posted: May-16-2006 at 9:53am
I am not sure what you are wanting, but my $.02 is that if you have the exhaust outlet flaps, you are as safe as you are going to get. If your engine does not have the exhaust riser, then I would be careful when backing hard and avoid abrubt stops in following seas (i.e. a roller coming in from behind).
Also, I am not really sure how it would happen other than using an aftermarket cam with overlap. Basically, the overlap leaves the exhaust valve open a bit as the piston starts to travel down (right? Helps scavenge the cylinder?) I guess this can draw water in. Otherwise, the exhaust forces will prevent water from coming in if the engine is running.
Posted By: Tim D
Date Posted: May-16-2006 at 1:15pm
If there is air in the exhaust(manifold & plumbing) water coming in will not be able to displace very much.
------------- Tim D
Posted By: 73skier
Date Posted: June-06-2006 at 10:56am
don't see how correct craft would make a boat with out flaps and sell it. In 73 they didn't even come with flaps thought it was an aftermarket thing to make them quiet or not as loud
Posted By: p/allen
Date Posted: June-06-2006 at 11:26pm
The only way i can see it happening is if you are sitting on a lift with the exaust a few inches out of the water and a wave comes in and pushes water up your exaust. Otherwise your exaust is under water any way . Awave is mostly an up and down motion not a forward motion inless it is rolling . my .02
Pat
------------- Pat
http://i175.photobucket.com/albums/w146/72ccfan/100_5977-1.jpg - My 72 Skier
Rock River
Dixon,ILL.
Posted By: Tim D
Date Posted: June-06-2006 at 11:40pm
If a wave pushes water up the exhaust, I don't think it can compress/displace the air very much that is already in there.
------------- Tim D
Posted By: 79nautique
Date Posted: June-07-2006 at 8:56am
if you have mufflers it doesn't matter, if you don't have mufflers then it could be a concern.
Posted By: stang72
Date Posted: June-07-2006 at 10:43am
I'm thinked Tim D's point makes sense...air should stop any water from moving to far and at the elbow it would have to be forced pretty hard.
Many olded CC's had no exaust flaps...my 62 is without them...
------------- stang
http://www.correctcraftfan.com/diaries/images/3720/photo1.jpg" rel="nofollow - The Super Air
Posted By: p/allen
Date Posted: June-07-2006 at 6:00pm
Tim D's point is correct if the exaust is completly sealed by water . But if the tube were only 1/2 full then the air would rush out above the water providing the water was moving quickly. I believe this is a very unlikely scenario and probably would not have enough force for the water to reach the engine .
Pat
------------- Pat
Rock River
Dixon,ILL.
Posted By: SS-201
Date Posted: June-12-2006 at 5:20am
CC exhaust are a closed system, reversison is not a problem, the exhaut system is higher than the stringers.
------------- SS 201
Posted By: p/allen
Date Posted: June-16-2006 at 8:01am
Some how the coolant water has to mix with the exhaust , so i guess i dont know what you mean by a closed system
Pat
------------- Pat
Rock River
Dixon,ILL.
Date Posted: June-16-2006 at 8:13am
The exhaust is seperate on a closed system and uses fresh water for the exhaust and the engine block get's the closed system water.
Posted By: Tim D
Date Posted: June-16-2006 at 8:51am
The exhaust and the water meet in the part called the elbow. The exhaust goes in the center of the manifold. The water goes down veins inside the outer walls of the manifold. If you ever took one apart, you would be impressed with the casting process.
------------- Tim D
