oil pressure sending unit
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=35833
Printed Date: October-07-2024 at 10:54pm
Topic: oil pressure sending unit
Posted By: jjojr1940
Subject: oil pressure sending unit
Date Posted: April-22-2015 at 12:42am
Is there a specific application for the oil pressure sending unit on a 1965 Interceptor SBF. We did a rebuild and this one just seems to want to pin the gauge at 80 lbs . ? I'm not the wiring guy (not a clue actually) , but I think we have it wired right. Any info I can relay to him is appreciated.
Posted By: mamigacz
Date Posted: April-22-2015 at 10:14am
jjojr1940 wrote:
Is there a specific application for the oil pressure sending unit on a 1965 Interceptor SBF. We did a rebuild and this one just seems to want to pin the gauge at 80 lbs . ? I'm not the wiring guy (not a clue actually) , but I think we have it wired right. Any info I can relay to him is appreciated. |
The application of the sending unit is based on the gauge, not the engine. The most likely causes for what you are describing are:
-An oil pressure switch (for an idiot light)is installed.
-The installed oil pressure sender has the wrong resistance range.
-The sender is defective.
A common sender resistance range used in marine oil pressure gauges is 33-240 ohms. A sender with the a 33-240ohm range is available on skidim for $37. Otherwise, if you want to find a cheaper substitute, they have them on ebay for about $19.
Date Posted: April-22-2015 at 7:41pm
John, Did you change the sender when you rebuilt the engine? If so, does it match the Ohm range of the gauge? You may have S/W gauges so check. DO NOT go buying a 33-240 sender from Skidim until you check.
If your gauge pegs at max, then you don't have any resistance on the sender wire. It may be wired incorrectly or a bad sender. Remove the wire from the sender and Ohm between the sender terminal and ground (the engine block). You should get resistance with the engine running or not.
Date Posted: April-22-2015 at 9:12pm
Okay, thanks for the feedback. I'll make sure my guy gets the info.
Date Posted: April-22-2015 at 10:07pm
jjojr1940 wrote:
Okay, thanks for the feedback. I'll make sure my guy gets the info. | John, The guy you have wiring will have a VOM so Ohming out the sender will be easy for him. Did you install a new sender? Do you have the S/W gauges?
