Oil Pressure Sending Unit
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=36002
Printed Date: November-17-2024 at 5:42am
Topic: Oil Pressure Sending Unit
Posted By: cmacbuck69
Subject: Oil Pressure Sending Unit
Date Posted: May-10-2015 at 12:21pm
In trying to get all of my gauges working properly, I'm having issues with the oil pressure gauge. The engine is a full rebuild that runs solid and the Oil Pressure gauge is stuck on 80 when I crank it up. We replaced the sending unit with a manual gauge and it was right at 60. The sending unit is a new unit form skidim. I think the wiring is correct to the gauge, but looking for any ideas...
Posted By: jhersey29
Date Posted: May-10-2015 at 12:46pm
Check the ohms reading at the sender with the wire to the dash detached. Put the wire back on the sender and check it at the gauge. Is it the same or close to the same reading?
Date Posted: May-10-2015 at 1:41pm
Chris, The sender terminal on the gauge is ether shunted to ground or the sender is the same. Get the VOM out and check as recommended above.
Was the old sender bad and the reason you put a new one in?
Date Posted: May-10-2015 at 4:22pm
After doing that it appeared I had the signal wire on the gauge connected to the bracket screw that holds the gauge in place. I put it on the S post on the gauge and both ohms readings were the same from testing at both locations. I could not get the engine to turn over for what ever reason to test it though and had to abort for the day... Ladies were starting to get restless...
Date Posted: May-10-2015 at 4:23pm
Also, I replaced the sender because I thought the old one was bad, but it appears to have been the wiring...
Date Posted: May-10-2015 at 5:43pm
Chris, Glad you found where the shunt to ground was.
Now the next step with the VOM is why it won't crank. See what you get at the S terminal on the ignition switch and then to the NSS and finally to the start relay I terminal. (with the key turned to start).
Date Posted: May-10-2015 at 5:53pm
Nice find. Good luck on the crank issue.
Date Posted: May-10-2015 at 11:07pm
Thanks for the assist! NSS = neutral safety switch correct?
Date Posted: May-10-2015 at 11:14pm
cmacbuck69 wrote:
Thanks for the assist! NSS = neutral safety switch correct? | Yup, I should have spelled it out to avoid any confusion.
Date Posted: May-16-2015 at 11:19pm
Good call on the NSS, The wires are good, but the ball must have got hung up, but its all good now.
