Ignition System
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=36273
Printed Date: November-17-2024 at 5:34am
Topic: Ignition System
Posted By: 73SN
Subject: Ignition System
Date Posted: June-08-2015 at 5:55pm
I'm getting real close to finishing assembly on my 351. I'm waiting on parts; I'm hoping to get it back in the boat this weekend or at least next week.
I've been reading up on the distributor, coil, and ballast resistor and I need a bit of clarification.
I've got an electronic ignition distributor and the ballast resistor was bypassed initially.
The old coil got tossed. I have another one but it clearly states on the outside: USE WITH EXTERNAL RESISTOR.
Which is dependent on the BR, the coil or the distributor?
The contacts inside old cap are a bit corroded but everything seems tight. I don't mind buying new if it'll help the engine start the first time and run better.
Posted By: JoeinNY
Date Posted: June-08-2015 at 6:29pm
either or both -
don't use a coil that needs an external resistor without an external resistor.
http://www.correctcraftfan.com/diaries/details.asp?ID=1477 - 1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Posted By: 73SN
Date Posted: June-08-2015 at 6:33pm
Alright, I'll look around and see what's available. Thanks
Posted By: 73SN
Date Posted: June-10-2015 at 12:52am
This one is $49 plus $11 to ship:
http://www.skidim.com/prodinfo.asp?number=R117004B" rel="nofollow - SKIDIM PCM COIL
Summit Racing has the MSD Blaster 8222 for about $54 shipped.
I'm leaning towards the PCM simply because it says "Coil EI" and Prestolite (which is the type I have).
Posted By: Bri892001
Date Posted: June-10-2015 at 12:15pm
That looks like a good choice to me. Are you working with a 2 wire or 3 wire dizzy?
Posted By: 73SN
Date Posted: June-11-2015 at 2:06am
2 wire: one purple + one black -.
Posted By: john_33612
Date Posted: June-11-2015 at 9:46am
this one will not overheat , comes with new resistor and mount     http://performanceparts.com/part/Mallory/29440
Date Posted: June-11-2015 at 10:12am
Then I believe the coil you posted, the one designed to run without a resister, is the correct one. You may wish to call Skidim on the phone just to confirm.
The reason I asked about number of wires, is because the 3 wire Mallory Electronic distributors actually need the coil to be run through a ballast resistor.
Posted By: Sleepyone
Date Posted: June-11-2015 at 11:06am
I replaced the whole thing on the 87 Nautique with the 454 with a Davis Unified ignition Marine HEI. Very hot spark and no trouble at all. This would be my prefered choise again as well.
Posted By: 73SN
Date Posted: June-11-2015 at 11:23am
Skidim said mine's the original Prestolite conversion with the purple and black and it should work fine.
We'll be boating soon...
