ignition coil
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=36538
Printed Date: October-07-2024 at 8:34pm
Topic: ignition coil
Posted By: dustyb
Subject: ignition coil
Date Posted: June-26-2015 at 3:26pm
what kind of coil do you guys recommend using? I have a 78 ski nautique with 351w and need to replace the coil, just looking for options. thanks
Posted By: gun-driver
Date Posted: June-26-2015 at 3:36pm
Depends on if you are running through the ballast resistor or not.
Posted By: dustyb
Date Posted: June-26-2015 at 4:00pm
yes it currently has one but depending on what coil I go with should determine weather or not I need it or not correct? I ran it without the resistor and it started to overheat the coil, with the resistor it seemed to not get enough fire. currently has a MSD blaster 2 coil
Date Posted: June-26-2015 at 7:30pm
| Dusty, You say it "seemed not to get enough fire". What tests did you do before throwing parts at it? What were the symptoms"
Posted By: dustyb
Date Posted: June-26-2015 at 8:49pm
had very poor throttle response. it would die when trying to pull a skier up, once I did away with the resistor it seemed to do a lot better
Date Posted: June-26-2015 at 9:16pm
| Dusty, "seemed to do a lot better" isn't really a test! Did you consider the problem may have been the carb?
