Dash Wiring diagram
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=36626
Printed Date: November-17-2024 at 3:23am
Topic: Dash Wiring diagram
Posted By: Heaktwin
Subject: Dash Wiring diagram
Date Posted: July-02-2015 at 4:26pm
Does anyone out there have a dash wiring diagram for a 1994 Nautique. I have a non-working gas gauge and other issues that I would like to trouble shoot. I am the second owner of this boat and it appears that the previous owner did some creative wiring for the sound system but otherwise it seems to be stock. I also have only one Speedo working and need to evaluate that while I have this thing apart. I would love to put it back together correctly. Thanks.
heaktwin
Date Posted: July-02-2015 at 8:22pm
David,
What other issues are you having other than the fuel gauge? With the gauge, check that you have + 12 volts nominal to the gauge, then continuity via the sender wire all the way back to the tank sender and then a ground continuity from the sender base to the engine block. The quick way to check the gauge is to remove the sender wire from the sender itself, ground it and the gauge will peg to full.
Posted By: Heaktwin
Date Posted: July-10-2015 at 5:43pm
Thank you, any chance you know where I can get a wiring schematic for the Nautique dash there appear to be several wires having loose with no obvious destination.
heaktwin
Date Posted: July-10-2015 at 7:54pm
It's common to have some extra wires. They may have been for options. Trace them and see where they go.
Posted By: sstichter
Date Posted: July-28-2015 at 4:31pm
Did you look in the reference section for the wiring diagram?
