Voltage Problem
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=36783
Printed Date: October-07-2024 at 6:26pm
Topic: Voltage Problem
Posted By: td_in_nc
Subject: Voltage Problem
Date Posted: July-18-2015 at 1:13pm
I will start this by saying I struggle with solving electrical issues.
I went out yesterday and when I started the boat each time, it sounded like I did not have a lot of power coming from the battery. It would be just enough to turn it over. At one point there was not enough juice to turn it over so I switched to the other battery. It also acted like it was low. When I got home I put the charger on it and it showed both batteries full. I tested with a multimeter and both checked at 12.5+.
I cleaned the battery and engine ground connections
When I check the voltage at the ignition switch it is it is 12.5, but when I turn to the key to the first position it reads 11.5.
I tested the volts from the starter to the ground 12v
Tested from positive on battery to engine ground 12v
Tested the voltage at the fuse box from Pos to neg and it was 12.5,
When I test the voltage from the battery positive to the hot wire on the ignition switch in the on position I get 1 volt (was hoping for 0), if I turn on the bilge I get almost a 2 volt reading..
Not sure where the problem is or how to pinpoint it, but suggestions sure would be appreciated. Tom
Date Posted: July-18-2015 at 1:28pm
Tom, One of the things you haven't mentioned is what type of battery(s) are you using. Also, you need to get a voltage reading at the starter when cranking. This will tell a lot since it will show the voltage drop. How are your battery cables?
Posted By: td_in_nc
Date Posted: July-18-2015 at 1:50pm
I have deep cycle batteries (which what came with the boat with 690 cranking amps an 101 amps/hour
Testing voltage from positive at starter to ground on engine it was 12.5 then when cracking it dropped 11.9 volts.
Posted By: Orlando76
Date Posted: July-18-2015 at 1:54pm
Oh boy you're gonna get reamed about the deep cycle. That's like asking which tube performs better. I myself feel the stock 351 is fine with it but everybody disagrees. Mainly your batteries won't last long with a deep cycle.
------------- Please support The Cystic Fibrosis Foundation 1976 Ski Nautique 351 Escort 1993 Ski Nautique purple and black 351 HO PCM
Posted By: td_in_nc
Date Posted: July-18-2015 at 2:13pm
Orlando76 wrote:
Oh boy you're gonna get reamed about the deep cycle. That's like asking which tube performs better. I myself feel the stock 351 is fine with it but everybody disagrees. Mainly your batteries won't last long with a deep cycle. |
Yep expecting that.
Date Posted: July-18-2015 at 2:17pm
Well, what can I say that isn't already a known problem!!
Date Posted: July-18-2015 at 3:41pm
Tom, The .6 voltage drop is not bad at the starter. Considering your batteries are rated in amp hours as well as cranking amps and the low drop, I'd have to say they are combination starting and deep which is a compromise between the two. There's also a chance that the starter isn't pulling the amps, then you will not see a big voltage drop so, I'd look at the starter is self. Personally I'd open it up and check the brushes and the commutator. If the brushes look short replace them and then clean up the commutator. I wish there was an easy way to get amp draw on a starter but it involves a shunt or current doughnut and meter that most don't have.
Posted By: DVskier
Date Posted: July-18-2015 at 4:54pm
Date Posted: July-18-2015 at 4:58pm
Won't take a charge, barely turning the engine over... Time for a new battery. Don't buy a deep cycle. :)
Date Posted: July-18-2015 at 6:47pm
DVskier wrote:
Amprobe.
| Find one that will handle 600 amps DC!!!
Date Posted: July-18-2015 at 6:50pm
TRBenj wrote:
Won't take a charge, barely turning the engine over... Time for a new battery. Don't buy a deep cycle. :) | Unless stated voltage drop is incorrect, it's saying no but a load test on the batteries is not a bad idea.
Date Posted: July-18-2015 at 7:39pm
I've been mislead many times by batteries that show "full charge" (12.5v) but don't have the capacity to crank an engine (fast or at all). Load test it by all means, but the fact that they're deep cycle and at least a few years old makes them suspect IMHO.
Posted By: baitkiller
Date Posted: July-18-2015 at 7:44pm
My guess is a bad Perko switch. I see it all the time and seldom does anybody ever consider it a possibility. I have seen starters and batteries and even cylinder heads pulled for a bad Perko switch, Easy trouble shooting is load test the batteries, Fine? Ok now put the tester on the battery connections at the starter. Low? Put the tester on the switch terminals and you can now load test in and out of the switch.
------------- Jesus was a bare-footer.............
Date Posted: July-18-2015 at 9:08pm
TRBenj wrote:
I've been mislead many times by batteries that show "full charge" (12.5v) but don't have the capacity to crank an engine (fast or at all). Load test it by all means, but the fact that they're deep cycle and at least a few years old makes them suspect IMHO. | Tim, You have been fooled by a surface charge . It will show good volts but you are correct that's not under load. The load test will tell for sure but in this case the starter is close to a load test. With a load tester, it's cranked up to 1/2 the CCA of the battery for 15 seconds and volts shouldn't fall below:
Electrolyte Temperature °F Minimum Voltage Under LOAD 100° 9.9 90° 9.8 80° 9.7 70° 9.6 60° ° 9.5 50° 9.4 40° 9.3 30° 9.1
In this case if the readings are correct, the drop was .6 volts when cranking (under load) so that's what's got me thinking starter and it's brushes.
Date Posted: July-18-2015 at 9:11pm
baitkiller wrote:
My guess is a bad Perko switch. I see it all the time and seldom does anybody ever consider it a possibility. I have seen starters and batteries and even cylinder heads pulled for a bad Perko switch, Easy trouble shooting is load test the batteries, Fine? Ok now put the tester on the battery connections at the starter. Low? Put the tester on the switch terminals and you can now load test in and out of the switch. | He's already done that. Please read again. No voltage drop so it's not whatever switch he has for the two batteries.
Posted By: td_in_nc
Date Posted: July-19-2015 at 9:43am
Thanks for the suggestions. I will have the batteries load tested,. If they test well I will look at the starter. Will keep you posted but it will be a little while before I have a chance to work on it.
Tom
Posted By: DVskier
Date Posted: July-19-2015 at 11:09am
Free Ground Shipping Offer (On Products over $75)
Amprobe ACDC-54NAV 1000A AC/DC TRMS Navigator Clamp Meter
New - Factory Authorized Distributor - Factory Warranty
TRMS. Voltage up to 1000 V AC/DC, resistance, frequency, THD (Total Harmonics Distortion) and individual harmonics form 1 to 25, power, power factor. Up to 1000 A AC Current. Up to 1000 A DC Current. CAT IV 600 V /CAT III 1000 V safety standard. Temperature measurement in °C or °F - Temp. adapter and probe included Phase rotation indication. Non-contact voltage detection. Inrush current measurement for motors. Low pass filter for variable frequency drives n Continuity Beeper. Min, Max and Smart Data Hold. Peak hold. Auto torch-light when clamping. Large 10,000 count display with active backlight and analog bar graph. Auto Power Off. Maximum jaw opening 1.77” (45mm). 4 feet drop proof. Deluxe carrying case Included. Complete with a full range of diagnostic capabilities including phase sequence, power and power factor, total harmonics distortion and individual harmonics, inrush current and low pass filter, the Amprobe ACDC-54NAV Navigator Clamp serves as a first line of defense for spot checking and verifying system conditions before deploying more specialized tools -- or incurring additional costs. It is rated CAT IV 600 V, CAT III 1000 V meter with voltage measurement up to 1000 V AC/DC. The new innovative navigation system eliminates confusing push buttons, and replaces them with a single joystick allowing the user to select functions directly on the display.
Date Posted: July-19-2015 at 12:31pm
David, Thanks for the Amprobe info. I'm sure out of date with what's available these days. I should have looked before commenting. I will however forgo the $300 + for now!
Posted By: DVskier
Date Posted: July-19-2015 at 12:36pm
Good tools = good troubleshooting. I have had an Amprobe since 1985. Many also forego your advice to use a VOM.
