Ski Pylon Repair
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=36799
Printed Date: November-17-2024 at 3:54am
Topic: Ski Pylon Repair
Posted By: DSmall
Subject: Ski Pylon Repair
Date Posted: July-20-2015 at 12:19am
I've recently removed my seat on my boat around the ski pylon, while doing this I noticed my ski pylon is bent (not sure if it's made that way or not). I also looked at the plate mount at the bottom of the pole. I had planned to just take the pole to a dealer and ask them if it's supposed to be bent. When trying to removed the anchor plate I noticed the screws holding it down felt unusually loose. I tried turning them by hand and ended up being able to pull them straight out without the need of any tools. I know this isn't supposed to happen. I pushed one of the screw back into the holes it came out of and felt a very spongy material with my knowledge of woodwork I'm assuming this is a block of wood that these bolts attach to. I've researched how to replace the subsurface wood and have found nothing back on it. Has anyone ever replaced the subsurface wood for the ski pylon ? I can't find any sources of information and I can't see any type of access to its location. The only thing I could think of is to either remove the boat decking to see if their's any access on the sides of the boat or to cut straight into its location replace the wood block and re-glass it on it's top side. I also have no clue how long this said piece of wood is. Any information, resources or any guidelines from someone who has done this before would be greatly appreciated. By the way this is on a 1999 Sprint Funsport - and the company who made this boat is no longer in business.
Posted By: SNobsessed
Date Posted: July-20-2015 at 12:30am
I don't know how your boat is built, but I think you should plan on cutting the floor out for several feet around the pylon & then evaluate the extent of decay. You could have rotten stringers, which is big job to replace.
Posted By: DSmall
Date Posted: July-20-2015 at 1:09am
If those were bad I would have deck sagging correct? I don't have this problem at all is it possible it's just the one and the other aren't affected or are not at this stage of rot yet?
Date Posted: July-20-2015 at 7:25am
Daniel, In this section, there is a FAQ thread. In it, you will find links to stringer replacement. I'm sorry to say that it sounds like you have a classic case of rot. The problem goes way beyond a block of wood under the pylon.
Posted By: Gary S
Date Posted: July-20-2015 at 9:34am
Trouble is not one of us on here knows how a Sprint Funsport is constructed. Is wood only used in the ski pylon area or does the boat use wood thru out- who knows. I think you are unfortunately pretty much on your own.
Posted By: DSmall
Date Posted: July-20-2015 at 2:33pm
Thanks for all the info guys just going to separate the top from bottom and see what I surprised with.
