Sliding Boat Hoist
Forum Name: Off Topic
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=36903
Printed Date: January-22-2025 at 6:00pm
Topic: Sliding Boat Hoist
Posted By: hall.cullen
Subject: Sliding Boat Hoist
Date Posted: July-30-2015 at 8:06pm
Hi all,
I have been a long time reader, however, this is my first post.
We are building a boat house at our lake place in Lodi, WI (lake Wisconsin) and I would like to bounce an idea off of you all.
The boat house will be just off the shore and will be using a rail system to get the Nautique and out of the boat house - most people with ski boats on the lake use this system and it seems to work well. The boat house will be 24' X 28" as large as we are allowed.
The issue here is that it seems we are only "allowed" by the DNR to have one set of rails go into the lake with the boat house being wide enough to allow for two boats. With one set of rails its really only good for one boat......
The solution I am considering is adding four steel posts inside the boathouse with a 8X35 I-beam across the tops of the posts, then adding a chain-hoist and trolley per beam centered above the lifting eyes of the boats. This way I can lift one boat off the rail system bunks for cleaning and maintenance but also to "slide" one boat to the other side of the boathouse leaving me clear path to pull in another. See my attached diagram.
I would of course have foam blocks or something under the boat when I am working under it should the unfortunate happen. I have done the math to ensure the beams are able to carry the weight, I expect only .17" of deflection of the 8X35 beam with the boat suspended in the center (worst case).
Has anyone ever seen something like this done? Any thoughts on how to improve it? Any thoughts as to why this might not work?
------------- 1994 Ski Nautique ProBoss 5.8L carbed with ProTech Ignition, 2000 Ski Nautique GT-40
Date Posted: July-30-2015 at 8:11pm
Initial Drawing of boathouse - this might help someone see what I am talking about.
Posted By: hdspringer99
Date Posted: July-30-2015 at 10:23pm
That seems to be simple but not as effective as building a railroad type switch. That way you can easily launch either boats quickly. What type of rail is being used?
------------- 77 Ski Nautique
Posted By: 74Wind
Date Posted: July-30-2015 at 10:34pm
That switch is a BRILLIANT idea!
Even if you have to set the boathouse back a bit further to allow space for it between the house and waterline.
------------- 1974 Southwind 18 1975 Century Mark II
Date Posted: July-30-2015 at 10:38pm
Cullen, I highly recommend consulting a structural engineer. You didn't mention the span but the description makes it about 15' min so the W8 35 seems to be on the light side.
| Track/dolly systems are commercially available. Some use light rail and some C channel. I suggest a search to familiarize yourself. The switch idea won't work. As stated, the DNR is very strick on what's between the boathouse and the HWM so the switch would need to be inside the boathouse. There's not enough length!!
Posted By: SNobsessed
Date Posted: July-30-2015 at 10:45pm
How about a 2nd door on uphill side of boat house. Use a hoist to load onto trailer. Agree with Pete, a Professional Engineer signoff is the only way to avoid liability issues down the road.
Posted By: 74Wind
Date Posted: July-30-2015 at 10:46pm
Wow Pete, that's an absurd ruling. My lake (like many here) is owned by Georgia Power so they can set their own rules, but if it's a public lake there that seems like an infringement since it would all be above the HWM, do they have some right of way over the first 10 feet or something?
Date Posted: July-30-2015 at 11:02pm
74Wind wrote:
Wow Pete, that's an absurd ruling. My lake (like many here) is owned by Georgia Power so they can set their own rules, but if it's a public lake there that seems like an infringement since it would all be above the HWM, do they have some right of way over the first 10 feet or something? | Building on Wisconsin lakes is very restrictive. The set back for homes is 75'. Boathouses can only be single story and yes, the DNR considers the 10' to be public land. The list goes on and on! I do not consider the ruling to be an infringement. If there weren't rules, I'd hate to look at what some would build so to me it's not absurd!
Date Posted: July-30-2015 at 11:11pm
Hall, Why the columns inside the boathouse? Clear up the area and set them in the wall. I've got W14's setting on 6x6 engineered.(LSL).
Date Posted: July-30-2015 at 11:16pm
No good reason, I think i just had it in my head that the boathouse the hoist structure would be seperate. Its worth looking into and excactly the feedback i was looking for!
Posted By: 74Wind
Date Posted: July-30-2015 at 11:18pm
Oh I agree with the anti-ugly thing Pete. On my lake in NY you are only allowed to build a house with a footprint no larger than the former house. So in some cases people have torn down a cottage and built a tall gauche house in it's place. The mcmansion theory, luckily only a few have done it.
We'Re just talking about some track here though, c'mon......
Date Posted: July-30-2015 at 11:27pm
hall.cullen wrote:
No good reason, I think i just had it in my head that the boathouse the hoist structure would be seperate. Its worth looking into and excactly the feedback i was looking for! | 10" of my W14's is also tucked up between the truss's giving me more room under the hook. The ends are slightly beveled to clear the roof.
Date Posted: July-30-2015 at 11:30pm
Hall, I just noticed you're from Chaska. Why would you come down to Lodi when you have so many great lakes in your own state?
Date Posted: July-30-2015 at 11:38pm
That is a good question! I grew up near Dubuque iowa and this lake when we looked for lots to build on checked a lot of the right boxes. Its not ideal for my folks or my family but i can be there in three hours or so and my folks can be there in an hour and a half.
Posted By: C-Bass
Date Posted: July-31-2015 at 10:35am
8122pbrainard wrote:
hall.cullen wrote:
No good reason, I think i just had it in my head that the boathouse the hoist structure would be seperate. Its worth looking into and excactly the feedback i was looking for! | 10" of my W14's is also tucked up between the truss's giving me more room under the hook. The ends are slightly beveled to clear the roof. |
^ Do this. In fact I followed this exact suggestion when I built my garage (and it was Pete who recommended it then). The ends did need beveled.
------------- Craig 67 SN 73 SN http://www.correctcraftfan.com/diaries/details.asp?ID=6103" rel="nofollow - 99 Sport 85SN
Posted By: Hollywood
Date Posted: July-31-2015 at 11:06am
hall.cullen wrote:
The boat house will be 24' X 28" as large as we are allowed. |
Is it an area restriction or dimensional? Reason I ask is why not make it long and skinny for 2 boats front to back, each on it's own cart. No hoists needed. The rail would just have to be a little deeper to sink the downhill cart and still clear with the uphill one.
Posted By: JayG80
Date Posted: July-31-2015 at 11:12am
That is very creative solution. I had a different issue on storing my boat trailer.
I built my house, with a double and single car garages. The ceiling in the single garage for the trailer is 11 ft tall with a 7 ft tall door. I built timber beams in the ceiling above the sheetrock. Use 4 of the same chainfalls and hoisted the trailer to live next to ceiling.
The garage door opens below the bottom of the trailer. Trailer has extra safety chains and has not been down in years since boat stays in the boathouse.
Took off the boat guides and wheels.
------------- 2007 Ski 2002 Ski
Date Posted: July-31-2015 at 11:31am
From what I have been able to piece together its an area thing, however, there might be some additional restrictions that I am not aware of (learning about these rules as I go). At this point what I know is we cant have more than 650 sq/ft of floor space.
Date Posted: July-31-2015 at 7:31pm
Hollywood wrote:
Is it an area restriction or dimensional? . |
hall.cullen wrote:
From what I have been able to piece together its an area thing, however, there might be some additional restrictions that I am not aware of (learning about these rules as I go). At this point what I know is we cant have more than 650 sq/ft of floor space. | It's not the area. It's a state wide DNR restriction. The other big one is it can only be one story tall and no deck on top.
Date Posted: August-02-2015 at 10:21am
| http://s133.photobucket.com/user/brainard_bucket_bucket/media/DSCF0013-6.jpg.html" rel="nofollow">
