Speedo Lens Replacement
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=36952
Printed Date: November-16-2024 at 9:28pm
Topic: Speedo Lens Replacement
Posted By: chuckactor
Subject: Speedo Lens Replacement
Date Posted: August-04-2015 at 6:29pm
I have a 1985 Ski Nautique. I was working to tidy up the cosmetics and would like to tackle the speedos. First off, I'm not sure what brand they are. Below is a picture (sorry I ripped the picture off.... mine are just like this, but I'm at work).
http://s17.photobucket.com/user/chuckactor/media/Boat/speedos.jpg.html" rel="nofollow">
The question is about the lens. It almost looks like there is black ring that is painted around the perimeter of the lens between the bezel and the numbers.. Like the picture above, the black paint is cracking and coming off. Does anyone know if you can get new lens or can I cut a ring of thin black plastic to sandwich under the lens?
Chuck
Date Posted: August-04-2015 at 6:43pm
Airguides. Lens is glass. Ring is painted. You can clean and repaint. Only replacement lenses being sold are the curved ones. Flat ones were only used 85-86.
Date Posted: August-04-2015 at 8:47pm
Cool.. that should be relatively easy. Since they are glass, they will strip easy and then I can get a vinyl place to make me a sticker to go in the middle for masking.
Chuck
Posted By: Gary S
Date Posted: August-04-2015 at 9:25pm
Look for 1 shot sign painters paint. I think you can get it at d*ck Blicks art stores. Sign painters used to paint on glass
Date Posted: August-05-2015 at 1:33am
Thanks! I was wondering what kind of paint would stick to glass.
Date Posted: January-08-2016 at 11:14pm
I finally got around to my winter projects. I pulled the speedos to replace the lenses. I can not get the bezels off of the speedometers. It feels like the are glued on. No amount of tugging and pulling will budge them. Any tricks to getting them off?
Chuck
Date Posted: January-13-2016 at 8:46pm
So I ended up using the side of a wooden paint stirring stick to knock the bezels off. I held the speedos and the stick on the edge of the bezel and had my wife tap it with a hammer. After going around a few times, they came off.
The needles were looking pretty shabby. All the orange paint had basically faded away. I popped the needles off and lightly sanded the surface with 400 grit paper. I tried to just remove the old paint and leave the white base layer from the old coating. After that, I painted them with two coats of a fluorescent red-orange model paint.
http://s17.photobucket.com/user/chuckactor/media/Boat/needle.jpg.html" rel="nofollow">
The original speedos had a black ring painted on the glass to cover the gap between the dial and housing. Instead of repainting the glass I decided to make a thin plastic ring to sandwich between the lens and the housing gasket. I found some textured 0.020" polycarbonate film and had the rings laser cut. I then spray painted the flat side with matte black spray paint.
http://s17.photobucket.com/user/chuckactor/media/Boat/ring.jpg.html" rel="nofollow">
Here is how the rings look placed inside the housing. The textured side will be against the glass to avoid damaging the painted surface. it also should prevent the rings from wetting to the back of the lens surface.
http://s17.photobucket.com/user/chuckactor/media/Boat/face.jpg.html" rel="nofollow">
I'm going to let all the paint dry overnight before putting them back together. Should look pretty good.
Chuck
Date Posted: January-14-2016 at 2:25pm
All done. Now to move on to the shifter. I'm avoiding tackling the seat bases....
http://s17.photobucket.com/user/chuckactor/media/Boat/speedo.jpg.html" rel="nofollow">
Chuck
Date Posted: January-14-2016 at 4:21pm
Chuck,
Nice! I like the plastic ring idea. It looks great and I hope it works out.
