Leak in Rudder Housing
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=36954
Printed Date: November-17-2024 at 1:50am
Topic: Leak in Rudder Housing
Posted By: sstichter
Subject: Leak in Rudder Housing
Date Posted: August-05-2015 at 1:20am
There is a drip from the area indicated by the arrow. Can I take it apart and look at stuffing/o-rings while it's in the water?
Just for my information, how does water come up into the rudder assembly?
I put 5200 on the bottom of the boat around the rudder plate. It made no difference in the leak.
Posted By: jhersey29
Date Posted: August-05-2015 at 1:31am
Don't take it.apart in the water. Your rudder will fall out and be in the bottom of the lake. Water comes up because there is a small gap between the rudder and the part shown above. The packing creates the seal but yet still allows for smooth movement of the rudder. If the rudder was pressed in it wouldn't turn so there is a gap. Replace the packing on land put it all back together just about hand tight on the top nut and adjust for minimal to no dripping when in the water.
Date Posted: August-05-2015 at 2:58am
Thank you! So, the packing in the nuts should prevent drips, yes? Tight and sealed enough to prevent drips, but loose enough to turn smoothly...
Date Posted: August-05-2015 at 7:26am
Before replacing the packing in the port, Tighten the gland first. This can be done in the water.
Date Posted: August-05-2015 at 11:19am
The gland is the largest ring/nut?
Date Posted: August-05-2015 at 11:23am
Which way will the gland go? Does the gland tighten to the right or the left?
Posted By: Hollywood
Date Posted: August-05-2015 at 11:59am
The "gland" is the packing itself. There is a seal inside the big nut. Back off the little jam nut. Look closely at the threads, you will see which way to turn. Then snug the jam nut back against the big once once adjusted properly.
Posted By: a0128
Date Posted: August-05-2015 at 1:50pm
sstichter wrote:
So, the packing in the nuts should prevent drips, yes? |
Except when the temp and relative humidity is above 90. In that case your nuts are going to drip no matter what you do.
Date Posted: August-05-2015 at 7:59pm
sstichter wrote:
Which way will the gland go? Does the gland tighten to the right or the left? | Samantha, Do you possibly have a friend who could help out and show you the tightening procedure? If not, the gland has a RH tread on it so clockwise looking at the top will tighten it.
Date Posted: August-05-2015 at 11:11pm
Well, that might explain it! Yea, it's been above 90 all summer. I'll take a pipe wrench and see if there's a bit of tightening to be done, but... that might be the answer, yes?
Date Posted: August-06-2015 at 12:12am
Pipe wrench be careful. You don't need much torque. This is a great wrench for that area. http://m.sears.com/plumb-pak-locknut-adjustable-wrench/p-SPM6169242101" rel="nofollow - http://m.sears.com/plumb-pak-locknut-adjustable-wrench/p-SPM6169242101
Posted By: JayG80
Date Posted: August-06-2015 at 9:52am
Over tIghten the gland nut and you will not be able to easily turn the steering wheel
------------- 2007 Ski 2002 Ski
