Fake lake alternative
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=37140
Printed Date: November-17-2024 at 1:54am
Topic: Fake lake alternative
Posted By: scottsims1
Subject: Fake lake alternative
Date Posted: August-22-2015 at 2:29pm
Thanks to all that helped me with the impeller change, it was very easy! So now that I have done that, I want to assure there were no other issues before the painful tow to the lake with the family. Is there an easy way to run water through the boat so I can run it and make sure it doesn't overheat? I don't have fake lake and don't want to run it dry..??
Posted By: NCH20SKIER
Date Posted: August-22-2015 at 2:44pm
Search this site for winterization process and it will show how to run anti freeze out of a 5 gallon bucket. Simply omit the af and keep the hose running into the bucket. I would suggest using a clear hose from the bucket to your inlet line.
Posted By: KRoundy
Date Posted: August-22-2015 at 3:00pm
From the FAQ:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=24767&title=how-to-run-your-boat-out-of-water-bucket-method" rel="nofollow - Bucket method for driveway running
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=33560&title=awesome-bucket-method-video" rel="nofollow - Bucket Method Video
Date Posted: August-22-2015 at 5:01pm
Stupid CCF clothing sale pop up blocking all the text...
Posted By: KRoundy
Date Posted: August-22-2015 at 6:31pm
What?
Posted By: Toertel
Date Posted: August-22-2015 at 9:06pm
guess he's using a smartphone
1994 Sport Nautique
Posted By: dangerwil
Date Posted: August-22-2015 at 9:53pm
plunger, barbed hose fitting, hose clamp, piece of conduit. ~ $8
Posted By: HondaF1
Date Posted: August-24-2015 at 11:53am
Question alone the same lines as the OP.
My SN has a Perko Pro fresh water flush kit installed. Could I use this instead of Fake a Lake (see attached picture)? Likewise for winterization could I not also feed anti-freeze in through the Perko Pro device? Thank you advance.
Date Posted: August-24-2015 at 9:34pm
I hope it stays in one piece. Perko has supposedly improved them but they have been know to break! For simplicity, ruggedness and a device that works, I'd go for the one and only Timmy T!!
As for sucking in the antifreeze, I go with the pour in method as many do and also the suggested method by PCM!!! No buckets. No hoses, No mess. Uses less antifreeze too!
Posted By: HondaF1
Date Posted: August-24-2015 at 10:20pm
I am sure you are trying to be funny but I have no idea what this means - "I'd go for the one and only Timmy T!!" Again if the Perko does not blow the entire boat up can it be used in place of fake a lake? Thank you
Date Posted: August-24-2015 at 11:01pm
I'm not trying to be funny at all. The timmy t is simply a hose connection method that one of our oldest respected members came up with. A quick search and http://www.correctcraftfan.com/forum/forum_posts.asp?TID=35646&title=advice-for-reviving-a-87-sn-2001-after-10yrs" rel="nofollow - I found this thread. It couldn't be simpler nor will it break.
