Question for drain block only guys
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=37684
Printed Date: November-16-2024 at 8:44pm
Topic: Question for drain block only guys
Posted By: Cumby
Subject: Question for drain block only guys
Date Posted: November-16-2015 at 4:08pm
For those of you that drain your block only and don't add antifreeze, what do you do about your impeller at spring start up? I'm not removing my impeller, so if I drain the block only, should I at least refill with water manually before I start it up in the spring?
99 Ski Nautique GT40
Date Posted: November-16-2015 at 4:20pm
Glen,
I have never done anything with any of my boats. A rubber impeller pump is self priming.
Posted By: Jonny Quest
Date Posted: November-16-2015 at 5:46pm
Yes, I drain the block, exhaust manifolds, "U" and trans cooler. To de-winterize, I fire up in my driveway with the garden hose hooked up to a "T" between the trans cooler and water strainer. The hose method sends water right up to the impeller, so it isn't running dry -- even for a few seconds.
I've seen some folks remove their impeller and raw water pump as part of the winterizing process. The claim is that an impeller that is removed is less likely to have the vanes "take a set" while sitting curled up over the winter. Others claim that there is no harm in allowing an impeller to sit inside the raw water pump all winter long. I typically change out my impeller every 2 years. I'm not a run-until-failure guy, so I don't push the impeller life as some other might. From my perspective, its a reasonably inexpensive bit of insurance. However, I do remove my raw water pump and inspect the innards at the beginning of every year.
Posted By: Tim D
Date Posted: November-16-2015 at 8:01pm
By refill, do you mean fill the block? The rwp will fill the block first, then water will go out the exhaust. Most people don't realize that when you take you boat out of the lake, the block is not entirely full. The intake area won't have any water. Most boats you can hear the intake fill when you first crank it when you put it back in the water.
Tim D
Posted By: FredWSauer
Date Posted: November-16-2015 at 10:12pm
I followed all the forum tips for winterize for draining the water, oil change, etc.. During a second round of reading, I found a little tip to NOT forget the heater under the dash. Went back to the storage garage with a flashlight and a small bucket of tools and pulled the hoses for the heater coil and blew into one until I got water to flow. Found plenty of water! I did not take the impeller out since I plan to replace next spring.
- FWS
1993 Ski Nautique
1978 Glastron T-160
1994 Weeres Pontoon - Wife's Boat
Date Posted: November-16-2015 at 10:54pm
Why?
I have never had one gone bad,some years I don't even remove them.
I've never blown one ether nor do I remove them for layup. This every 2 years is way overkill BS in my mind. These impellers (dual pocket) were still fine after 17 years
http://s133.photobucket.com/user/brainard_bucket_bucket/media/DSCF0010-7.jpg.html" rel="nofollow">
I changed them before I took the X55 to GL.
Posted By: Gary S
Date Posted: November-16-2015 at 11:01pm
Pretty new boat to him Pete,might not be a bad idea just to check on the PO. He can keep it for a spare if it's ok
Date Posted: November-16-2015 at 11:29pm
Fred,
Gary is correct since you don't know what a PO has done. Do plan on a new impeller next spring. From then on, it's your choice.
Posted By: Cumby
Date Posted: November-17-2015 at 9:31am
I remember reading somewhere a recommendation to put vaseline on a dry impeller when de-winterizing. Sounded like overkill to me since cold weather skiers drain their block regularly. I was wondering if you don't keep it immersed in antifreeze if its OK to drop it in the water and go. Im glad to hear its not an issue.
Date Posted: November-17-2015 at 9:54am
Glen and Fred,
Just don't buy the cheap Sierra impellers. There are reports of problems with them from good sources. Stick with the OEM impellers.
Posted By: Riley
Date Posted: November-17-2015 at 10:02am
I make sure the water pump is drained by rotating the pump with the plug out or hoses off. Replacing impeller every other year is not a bad idea on a boat that gets used a lot or if you have operators that you can't rely on noticing the engine is starting to overheat until there's smoke and steam coming from under the motor box.
Posted By: Hollywood
Date Posted: November-17-2015 at 12:04pm
Change your impeller only when it needs it, like underwear.
Posted By: SNobsessed
Date Posted: November-17-2015 at 4:19pm
Actually, removing the impeller might make it deteriorate faster. One of rubber's worst enemies is ozone. Leaving it in the pump would limit ozone exposure.
Posted By: BuffaloBFN
Date Posted: December-12-2015 at 9:08am
Aren't petroleum products hard on rubber?
I've done the impeller both ways and decided to
A-leave it in because a drain only can be water ready for that odd winter day.
B-it gets a good spring inspection
C-had 2 under the back seat
This is pre-heater.
http://correctcraftfan.com/diaries/details.asp?ID=2331&sort=&pagenum=12&yrstart=1986&yrend=1990" rel="nofollow - 1988 BFN-sold
Date Posted: December-12-2015 at 9:10am
This is so huge.
Posted By: sailsail
Date Posted: January-02-2016 at 11:19pm
Glen and Fred,
Where does one purchase OEM impellers?
Date Posted: January-02-2016 at 11:45pm
Ski Dim or N3 Boatworks are good sources.
Date Posted: January-03-2016 at 12:06am
http://www.jamestowndistributors.com/userportal/search.do?freeText=impellers&resultPref=all&page=GRID&history=v6e8s1qp%7Ctop_category%7Ccategory%7E56%5Epage%7EGRID%5Euser_att_name0%7EUserType%5Euser_att_value0%7ENewUser%5EsubCategoryName%7EPlumbing%5EcategoryName%7Ecategory_root" rel="nofollow - And Jamestown Or you can even do an on line search!!
Posted By: sailsail
Date Posted: January-03-2016 at 12:52pm
Thank you,
I also added pictures to the oil drain thread.
