Adhesive for Sano Step Pad on '92 SN?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=38157
Printed Date: November-16-2024 at 8:27pm
Topic: Adhesive for Sano Step Pad on '92 SN?
Posted By: desertskier
Subject: Adhesive for Sano Step Pad on '92 SN?
Date Posted: February-23-2016 at 5:47pm
I purchased some step pad rubber from Christines recently. It is to replace the rubber step pad that goes across the aft end of the boat just in front of the platform. I was going to use some DAP Weldwood Contact Cement but after reading the label is says it is not waterproof. DAP also make the HHR Contact Cement which looks like it would hold but it's only sold in gallons for about $50. Any ideas for a product that would bond rubber to gelcoat and may be more readily available for a reasonable cost? Thanks
Date Posted: February-23-2016 at 5:52pm
You can get small tubes of 5200 or 4200. It also wouldn't require the very careful placement of the pad as a contact adhesive would. Longer cure time would be the only disadvantage.
Date Posted: February-23-2016 at 6:12pm
3M doesn't mention rubber in the description but it looks like it would work. Thanks
Posted By: KRoundy
Date Posted: February-27-2016 at 2:26pm
You should follow up and post some pictures of this project!
------------- Previous: 1993 Electric Blue/Charcoal Ski Nautique Current: 2016 Ski Nautique 200 Open Bow
Posted By: ScottZ
Date Posted: February-28-2016 at 1:23am
I have used 3m spray adhesive.
------------- Scott Zuelzke Lake Mitchell , AL 1984 Ski Nautique 1972 Skier
Posted By: phatsat67
Date Posted: February-28-2016 at 9:40am
I made seadek replacements at N3. They are peal abs stick and look great. I believe that they are still in stock. Cheap too.
Posted By: Blamey
Date Posted: February-28-2016 at 10:14am
phatsat67 wrote:
I made seadek replacements at N3. They are peal abs stick and look great. I believe that they are still in stock. Cheap too. |
Zach, did you make ones for the '95 sport?
------------- 96 Super Sport Previously: 95 Sport Nautique, 1980 Ski Supreme
Date Posted: February-28-2016 at 10:24am
ScottZ wrote:
I have used 3m spray adhesive. | The reason I suggested 4200 is it gives you time for positioning that a contact adhesive doesn't. That 3M sticks and you had better put it down in the correct spot from the start!
Posted By: JPASS
Date Posted: February-28-2016 at 11:45am
Yup, you made one of me not too long ago, plus one for the top of the rear vent. They went on perfect and looked great.
Date Posted: February-28-2016 at 9:43pm
Now you tell me! I bought the Sano Pad with the "N" logo. It should look pretty good.
http://christinesmarine.com/Exterior_Parts___Accessories.html" rel="nofollow - Bottom of this page if anyone else is interested
They are also doing a few skins for me. Brought the boat home for the first time in 5 years. Spent 5 hours with muriatic acid cleaning the algae off the hull. Then spent the next two days wetsanding/buffing/polishing etc... It's actually starting to look pretty good again.
