Stringer Lag Bolt
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=383
Printed Date: September-27-2024 at 5:03pm
Topic: Stringer Lag Bolt
Posted By: nauti girl
Subject: Stringer Lag Bolt
Date Posted: May-17-2004 at 3:00pm
I noticed the left rear tranny-mount lag bolt into my stringer won't tighten up. All seven of the other lag bolts tighten up just fine. What's the next step? Should I buy a longer lag bolt and run it in deeper? (there's about another 2" to the bottom of the hull) Is Git-Rot good for this kind of problem? I'm not even sure if I have rot ...or if some previous owner over-tightened it and stripped it.
------------- Nauti Girl
--I think my husband uses his own login now!
Posted By: kenny g
Date Posted: May-17-2004 at 3:47pm
nauti girl, i had the same problem on 3 of em in the barracuda.go to home depot & get a wooden oak dowel rod the diameter of the hole.hammer it in & cut it off flush .
a little carpenters wood glue would help.
let it dry a day,then put your leg bolt back in.
------------- kenny g
Date Posted: May-17-2004 at 6:21pm
Thanks kenny g. Sounds like great advice. I assume I will need to re-drill the hole after drying?
Posted By: kenny g
Date Posted: May-17-2004 at 7:33pm
a small pilot hole wont hurt.
i diden't , but you can just dont go too big or your going to have the same problem you started with.
try to get oak,not white pine.
home depot has both.
Posted By: 64 Skier
Date Posted: May-20-2004 at 2:51pm
I had this problem....replaced the stringer, then welded an aluminum frame from under the front seat to behind the tranny.
A very knowledgeable CC mechanic told me I overkilled the problem. The wood just holds the lag bolts while the fiberglass is the structural support. He said to do as kenney g suggested or dig out the old rot and pour a glass bed about 6" long and re-tap.
------------- 64 Skier
66" HO VTX and 67" HO Triumph
http://www.correctcraftfan.com/diaries/details.asp?ID=1071&sort=&pagenum=3&yrstart=1971&yrend=1975 - 71CC
Posted By: jameski
Date Posted: May-20-2004 at 3:02pm
Doesn't the oak dowel split when you try to run a lag bolt into it?
------------- current boat
http://www.correctcraftfan.com/diaries/details.asp?ID=1977 - 94 Sport Nautique
previous boat
http://www.correctcraftfan.com/diaries/details.asp?ID=601 - 78 Martinique
Posted By: 64 Skier
Date Posted: May-20-2004 at 3:20pm
I would think the dowel would have a tendency to split if not supported.
Drilling and tapping the glass is pretty easy if you decide to pour-in a replacement for the stringer.
Mine was too far gone to support a dowel. I guess I could have dug out the rot, cut a 6" long board to fit back in (rather than the whole stringer...what a bonehead I was...I even had to pull the engine...so I rebuilt it...and so the story goes) put a little epoxy in the whole to let the new board bond and then pilot hole the board.
Probably a two hour job. My other way was about 4 months...my wife is still telling everyone about it
Date Posted: March-11-2005 at 9:22pm
I see my husband used my login again here! I am here for the party, not the technical stuff. I am here as an enthusiast, and perhaps learn a little along the way. I need to be able to handle myself when I decide to go out with the girls!!!
