Trailer tires, where's the best price online?
Forum Name: Common Questions
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=38370
Printed Date: November-24-2024 at 12:26pm
Topic: Trailer tires, where's the best price online?
Posted By: Warpman89
Subject: Trailer tires, where's the best price online?
Date Posted: April-04-2016 at 2:23pm
Good morning, I need to switch the tires on my trailer from the bias plies it has over to radials. The current size is 205/75d14. What is the best tire in this size for the price? I do a few 300 mile trips each year and the old tires are questionable. My barefoot nautique has the original Correct Craft two axle trailer but I have considered removing the front or rear axle if I can find tires with the correct weight rating to run a single axle. What do you guys do? Thanks
Stu
1982 BareFoot Nautique PCM 454 *Under Repair*
http://www.correctcraftfan.com/diaries/details.asp?ID=8077&sort=&pagenum=2" rel="nofollow - '82 BFN
Posted By: Hollywood
Date Posted: April-04-2016 at 2:30pm
You'd be better off trading someone for a single axle. Your weight distribution will be way off removing one or the other. The posted tire size is appropriate for that setup. I'd get C load range tires on the tandem, Ds on a single.
Date Posted: April-04-2016 at 2:34pm
I forgot to mention it but I'm interested in trading too. I would rather not cut up this trailer.
Stu
Posted By: JPASS
Date Posted: April-04-2016 at 2:44pm
If you're gonna go from a double axle to a single, you'll need to put an higher load rated single axle under there. Simply removing one existing axle, isn't going to cut it.
'92 Correctcraft Ski Nautique
Date Posted: April-04-2016 at 2:59pm
And springs, and yada yada but it kinda sounds like he has a plan for that route (which I hope he won't take.)
Posted By: FredWSauer
Date Posted: April-04-2016 at 9:35pm
I wished Hoosier tires made a trailer tire. I thought that would look sick with my 1993 SN. Then it would look good going fast on land too.
- FWS
1993 Ski Nautique
1978 Glastron T-160
1994 Weeres Pontoon - Wife's Boat
Posted By: quinner
Date Posted: April-04-2016 at 11:49pm
Bedrock tires rocks, ask for Fred or Barney
http://www.correctcraftfan.com/diaries/details.asp?ID=1143" rel="nofollow - Mi Bowt
