Carpet replacement advice
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=38471
Printed Date: November-16-2024 at 5:44pm
Topic: Carpet replacement advice
Posted By: t.franscioni
Subject: Carpet replacement advice
Date Posted: April-21-2016 at 2:24pm
Anyone have experience replacing carpet in there nautique? I'm Looking for suggestions on what to use for gluing down the carpet. Specific brands or products that anyone can recommend?
Posted By: AAM196
Date Posted: April-21-2016 at 3:52pm
http://www.homedepot.com/p/Roberts-1-8-x-1-8-x-1-16-in-Flat-Top-V-Notched-Economy-Trowel-10137-12/100207325?keyword=carpet+glue+tool" rel="nofollow - cheap tool
http://www.homedepot.com/p/Roberts-6700-1-gal-Indoor-Outdoor-Carpet-and-Artificial-Turf-Adhesive-6700-1/100117949?MERCH=REC-_-PIPHorizontal1_rr-_-202329533-_-100117949-_-N" rel="nofollow - indoor/outdoor carpet glue
for a bit more.. http://www.basspro.com/Boat-and-Outdoor-Carpet-Glue/product/44897/" rel="nofollow - Bass Pro shop sells
Date Posted: April-21-2016 at 9:32pm
Thank you.
Anyone replaced the carpet under the bow on an open bow nautique? I know that area was carpeted at factory before the top deck was installed so room is limited to work under there.... If it's been done with any success by anyone I would appriciate any advice on whether or not it's doable?
Posted By: LeftFieldEngineering
Date Posted: April-22-2016 at 12:08am
I used the applicator shown above with the 6700 carpet adhesive to cover my floor panels last year with great results. The trick with the 6700 is following the directions to a T, especially the drying 100% before contacting any form of water. Let it dry for a few days at the right tempiture and it should be fine.
Date Posted: April-22-2016 at 1:39am
Great that's what I wanted to hear. Personal experience with a specific product. I will plan on using the 6700 product that AAM196 is suggesting.
Posted By: RammerJammer
Date Posted: April-24-2016 at 10:14pm
Thomas, what type of carpet are you installing? Are you keeping it original?
------------- 1991 Nautique Excel, PCM 351, Pro-Tec ignition
Date Posted: April-24-2016 at 10:27pm
Yes I'm in middle of a full restoration on my 02 SAN. Goal is to keep it as original as possible for the most part. I purchased many carpet samples from several different vendors and settled on the "smoke Grey" 14oz carpet from Christine's marine as it provided the best match color wise. It's a little lighter weight than the 22oz original Capet but the color is my main concern because I won't be recaps ting under the bow seats or under the helm as that will be just too difficult I think to do as far as I can tell.
Posted By: DrCC
Date Posted: April-24-2016 at 10:34pm
Also keep all your carpet pieces running in the same direction. If one piece gets turned around, it shows and you probably won't be happy.
Date Posted: April-24-2016 at 10:53pm
Ya for sure I noticed that doing some mock ups with the sample carpet. Especially with the seat bases where you have to make sharpe bends with the carpet. Thanks for tip that's one I would forget when tracing my old carpet to make the cuts.
Date Posted: April-25-2016 at 9:29am
t.franscioni wrote:
the color is my main concern because I won't be recaps ting under the bow seats or under the helm as that will be just too difficult I think to do as far as I can tell. | Thomas, Get enough carpet to at least replace what's under the helm. After replacing the easy areas, you'll be a pro at it and the area under the helm will go real easy.
Date Posted: April-25-2016 at 11:52am
Ok I'd like to recarpet everything including under the bow. As I start ripping out the old carpet I will get a good idea of what's possible. I will plan on doing the underside of the helm then thanks! I will post some pictures here of my project as I go along.
Date Posted: April-25-2016 at 9:15pm
Got the old carpet out
Date Posted: April-25-2016 at 11:27pm
Thanks for the info, Thomas! I was looking at the carpet on NautiqueParts.com but it seems a little lighter than the shade in my boat, so I was curious. Where do you boat near Salinas? I lived in Monterey for a couple of years but didn't take my boat at the time.
Date Posted: April-26-2016 at 1:09am
Nacimento i would consider my local lake. Don Pedro over in San Joaquin valley is my favorite lake but only make it over there 2-3 times a year due to travel distance.
Posted By: RichK
Date Posted: May-30-2016 at 11:55am
How is the carpet replacement going? Did you take pictures you can share?
Date Posted: May-30-2016 at 12:13pm
I'm working on it. I'm in middle of a full boat restoration so I get caught up in other projects and bounce around from task to task. I got the carpet rough cut to shape for the floor and side walls but before I fit them I decided I would do all the gel coat work first so I don't sling polish and sanding dust all over the new carpet. So won't get to install the carpet for a couple weeks till gel coat is done. It's not letting me attach pictures here it says Iv "already uploaded a file with that name". I have a thread going at planet nautique forum called "2002 SANTE resto project" under the General nautique discussion tab. My carpet pics are posted there and more to come as I start installing it.
Date Posted: May-30-2016 at 12:17pm
Not sure why maybe it's because I do all this forum stuff from my phone but whenever I go to upload a picture on here it's says Iv already uploaded a file with that name. Then I have to go to my account settings and delete any pictures I have uploaded but then it seems that all the pics in my threads here on CCF get deleted also....
Date Posted: May-30-2016 at 12:23pm
Damn, looking above at my post a few replays up there is a picture of the new carpet rolled out on my driveway. That pic used to be a picture of all the carpet removed from my boat. Now since I tried to upload some new carpet pics the one that I did get loaded went up to that old post and replaced the original picture there. Is anyone else seeing that or is it just me and my phone is screwed up?
Posted By: RichK
Date Posted: May-30-2016 at 1:23pm
I think the general forum is having an issue. I see korean writing on the first page after the stickys.
