VDrive Impeller Replacement
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=3857
Printed Date: November-27-2024 at 6:14am
Topic: VDrive Impeller Replacement
Posted By: mjtrapp
Subject: VDrive Impeller Replacement
Date Posted: June-12-2006 at 2:27pm
I have a '99 Super Air V-Drive.
Apparently I need to replacce the impeller. Do they go out every season???
Has anyone attempted to replace a vdrive impeller on their own? How hard is it? Looks to be in a super tight spot.
Thanks.
FL Daddy
Posted By: mayberry
Date Posted: June-13-2006 at 10:01am
I haven't changed a Vdrive impeller, but it isn't difficult on a straight shaft motor. I wouldn't expect that it would be too difficult. I've owned a couple of Nautiques over the last 7 years, and they don't typically need replacing every year. If you crank your boat in your driveway without water circulating, it will burn up pretty quickly.
Posted By: p/allen
Date Posted: June-16-2006 at 7:57am
Impellers are supposed to be replaced every 2 years in clean lake water , every 1 year in dirty river water. I live on a river and finaly replaced mine after 8 years . It still looked good to me . The worst thing for them is running in the drive way without water, they will burn up . The second worst thing is for them to sit for more than a year because the ears will be folded over for to long inone spot and dry out , crack and break off then you may have to take off all hoses after pump and look for pieces .
Pat
------------- Pat
http://i175.photobucket.com/albums/w146/72ccfan/100_5977-1.jpg - My 72 Skier
Rock River
Dixon,ILL.
