Correct Craft 206 fuse box
Forum Name: Common Questions
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=38639
Printed Date: November-24-2024 at 12:26pm
Topic: Correct Craft 206 fuse box
Posted By: olivefromveyrier
Subject: Correct Craft 206 fuse box
Date Posted: May-16-2016 at 6:53am
Hi,
can someone help me. I can't find out where is the fuse box (Correct craft 206 2009 year).
The engine run, but the dashpod is off, and i guess the fuel pomp or ignition is also off
I found two fuses closed to the battery but my understanding is that is not the main fuses .
By advance thanks for your help
Kind regards
Oliver
Posted By: quinner
Date Posted: May-16-2016 at 9:38am
Check up under the dash pod should be a circuit breaker panel up there.
If your just missing some gauges it's possible you have a loose connection at your gateway box, assuming you have a keypad and not a keyed ignition.
http://www.correctcraftfan.com/diaries/details.asp?ID=1143" rel="nofollow - Mi Bowt
