68 289 Timing spec
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=3865
Printed Date: November-23-2024 at 1:54pm
Topic: 68 289 Timing spec
Posted By: captinr
Subject: 68 289 Timing spec
Date Posted: June-12-2006 at 10:34pm
Does anybody have the correct timing spec for a rev rotation 289 2BBL?
thanks as always
Rodney
Posted By: Jim_In_Houston
Date Posted: June-14-2006 at 12:45am
10 Deg BTDC per How to Rebuild Small-Block Ford Engines by Tom Monroe published by HPBooks.
BTW, my '68 289 seems to run better with about 14 Degs initial advance. It could be a distributor thing though. You should experiment with various settings but 10 Deg will get you running.
Posted By: SS-201
Date Posted: June-14-2006 at 5:28am
You are interested in full timing at 2500-3000 rpm. The inital will be what it is at idle. As I have stated before Ford chain and spockets have a retard built in. The fact the the chain streeches and goes further in retard. So unless you have a new chain and sprocket the inital will be a start. The full in in is the number.
SS 201
