GT-40 FCC leaking
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=38680
Printed Date: November-16-2024 at 5:43pm
Topic: GT-40 FCC leaking
Posted By: Mike Duffy
Subject: GT-40 FCC leaking
Date Posted: May-22-2016 at 12:53pm
The plastic part on the FCC that the wiring harness goes through cracked causing a fuel leak. Does anyone have a recommendation on what type of adhesive that could be used to repair? Or a replacement for the plastic part. Thanks
Posted By: Gary S
Date Posted: May-22-2016 at 1:32pm
I think http://www.nautiqueparts.com/kitfccpassthruretrofit.aspx" rel="nofollow - this is what your looking for. Don't think I'd be messing with some sort of sealant with those pressures on a fuel system. Thought there was some sort of recall on them but since I dont have one didn't pay much attention.
Date Posted: May-22-2016 at 2:41pm
Thanks Gary I agree a failure with high pressure fuel in a engine compartment not a good thing. I looked at that same part but did not know if was a retrofit. My old one had a compression fit rubber part which doesn't seem like a good design, so the replacement looks like you remove the plastic and use the o ring with a nut to secure. I'll contact Nautique parts on Monday. Thanks again.
Posted By: Luchog
Date Posted: May-22-2016 at 3:47pm
Since the introduction of ethanol on fuel, there has been an "upgrade" on the wiring fitting because of leaks.
Commander 351W
