Morse MV2 questions
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=38835
Printed Date: November-16-2024 at 5:36pm
Topic: Morse MV2 questions
Posted By: Orlando76
Subject: Morse MV2 questions
Date Posted: May-30-2016 at 6:24pm
I've successfully reassembled the MV 1? On the 75 & 76. Figured I'd clean and lube the MV2 on the '93 prior to installing new cables. After reassembling the controller I notice that when I pull the neutral pin I can still move the throttle backwards AND forward when in neutral, unlike the older controllers. Is this normal and Was it always like? I used up all my white lithium grease and don't want to pull it apart and have to run out for more.
------------- Please support The Cystic Fibrosis Foundation 1976 Ski Nautique 351 Escort 1993 Ski Nautique purple and black 351 HO PCM
Date Posted: May-30-2016 at 8:17pm
You can move the throttle forwards and reverse with the pin pulled on every morse I've ever used. Not full actuation, (one way is physically limited by the pulled pin on the mv1 and mv2) but at least to the idle detent or so in both directions.
Posted By: Hollywood
Date Posted: May-31-2016 at 12:19am
Yea both ways but you don't get full range forward.
Date Posted: May-31-2016 at 1:37pm
Bonehead move I kept checking it from the backside with the plate the cable attaches to WITHOUT the throttle arm on. Of course it has full motion that way, the throttle arm is what limits the forward motion because it hits the neutral pin.
