Suggestions on drilling hole in vinyl upholstery
Forum Name: Common Questions
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=38936
Printed Date: April-08-2025 at 9:57am
Topic: Suggestions on drilling hole in vinyl upholstery
Posted By: Orlando76
Subject: Suggestions on drilling hole in vinyl upholstery
Date Posted: June-07-2016 at 11:51pm
I need to install a kill switch on my '93. Ideally I'd like it in the combing pad near the shifter but that's upholstered with thin padding underneath. Should I just make a small cross hair cut in the pad then poke the ~1/2" drill bit in to go thru the glass? Then I was thinking a shot of super glue to the cut when done to help fuse it. My only other option that I can think of is to drill the switch in the right hand switch panel which I don't favor.
------------- Please support The Cystic Fibrosis Foundation 1976 Ski Nautique 351 Escort 1993 Ski Nautique purple and black 351 HO PCM
Date Posted: June-07-2016 at 11:55pm
Under the gunnel or dash.
Say no to holes.
Date Posted: June-07-2016 at 11:58pm
I hate holes too but I am a safety nerd. To mount under gunnel I'd have to make a bracket then epoxy it in? Maybe I'll find someway to mount it underneath.
Posted By: SNobsessed
Date Posted: June-08-2016 at 12:49am
Orlando76 wrote:
To mount under gunnel I'd have to make a bracket then epoxy it in? |
+1
Some ply or dimension board, 5 minute epoxy & it is a done deal.
I have tried to avoid permanent mods, at least ones that show.
Date Posted: June-08-2016 at 7:29am
Safety has nothing to do with drilling holes. I'd probably opt for aluminum over wood... Epoxy or screws can be used depending on the thickness of the mount location. Flat vs angle depends on the orientation and location... Here is how I mounted my new heater switch.
Date Posted: June-08-2016 at 7:48am
Tim, Very nice job with keeping the original look without holes.
Jeff, If you want to mount under the gunnel close to the helm throttle/shift, an aluminum bracket would be a good choice. If there isn't any backing to screw to, through bolt the bracket on behind the gunnel but hide the bolt heads under the combing pad.
Posted By: DrCC
Date Posted: June-08-2016 at 12:13pm
I luv the heater switch ! And I agree: "say no to holes" especially in padded vinyl.
I was drilling once, and the bit grabbed the foam rubber and pulled out a big chunk of foam rubber.
I made an underdash bracket for a 12v outlet and used the bottom bolts of the steering bezel to attach.
Posted By: Dreaming
Date Posted: June-08-2016 at 1:58pm
if you want to mount your kill switch in the combing pad, I don't think that's a bad location, mine is located there, and I believe it was a factory install... instead of cutting though, you'd need to punch a hole in the vinyl with a leather punch so that the stress put on the vinyl won't cause the "cuts" to continue. You'd have to take the skin off, and punch it, vs trying to cut/drill. I think it is more work, and may not have a great result, but if that is where you want your switch, it is worth a try. A template would be helpful in this case for marking the hole/switch/punch location.
