Batteries died
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=39046
Printed Date: November-16-2024 at 6:56pm
Topic: Batteries died
Posted By: trh250r
Subject: Batteries died
Date Posted: June-20-2016 at 2:21am
I had a weird event happen this weekend with my 2002 super air nautique TE. We hit the water and everything seemed ok. I did notice my blower motor wasn't working properly during the launch and the start to the engine seemed a little dull. We wake boarded for 3 sets then took a break for about 45 minutes. We listened to music while floating. As we started the 4th set, the perfect pass would not dial in properly. The audio also started to not play correctly and a lot of static occurred especially with the sub. I checked the battery gauge and it showed just above 10 Volts. We stopped and anchored down and jumped in another boat. We came back an hour later and the boat barely started. As I pulled away I gave it throttle and I could only go about 5-10 mph before the motor would muffle out and feel like it was going to stall. I finally got to the dock and shut down the engine. I tried to switch the batteries around and at this point to see if one was dead. I tried to start the boat with the batteries swapped and it wouldn't turn over. We put the boat on the trailer without getting the motor started and it was a disappointing ride home.
I'm not mechanically sound with my boat yet as I've only had it for less than a year and I am newbie when it comes to working on boats/diagnosing.
Any ideas what this would be? Alternator?
The batteries are 1 and 2 years old. I had them inside all winter and charged them occasionally. This was my third time out this year. I had no issues last year ( only ran it for about 30 hrs). I didn't have issues until this weekend. I charged my batteries today with a mini charger only having 1.5 amps. Right now one battery is at 12.38 and the other is at 12.08. While checking the 12.08 within 2-4 minutes it was down to 12.00. Not sure if using a meter draws any power if it did you'd think it wouldn't draw battery down that quick.
Posted By: Duane in Indy
Date Posted: June-20-2016 at 7:27am
Best bet is to take the batteries (in the boat or out) to a battery sales outlet (Walmart, or your local parts place) and have them LOAD TESTED. That will tell the condition of the batteries. Being only 1 or 2 years old does not mean as much as how the usage was during that time. They can also hook up an inline amp meter to tell if any of the components are drawing the battery down when parked.
As Pete would say "Deep Cycle or starting battery" Use starting type.
        1978 Mustang (modified)
Date Posted: June-20-2016 at 8:23am
Tyler,
As Duane mentioned, do have the batteries load tested as it's really the only test that truly tells the battery condition. Taking a static volt reading on a battery is pretty meaningless. If that 10 volt reading on your boats voltmeter was with the engine running, then there's something going on with your alternator. It should be removed and tested as well. Your auto supply can do that test too. No, using a VOM will not draw down a battery. Regarding starting and deep cycle batteries, the deep should be used to power the sound system and the starting to run the engine. How are they connected and do you have a "perco" switch connecting the two batteries?
Posted By: trh250r
Date Posted: June-20-2016 at 12:42pm
thanks guys, ill go get my batteries tested at advanced auto. I believe the batteries are connected together. I do not have a "perco" switch connecting the two batteries.
Posted By: Hollywood
Date Posted: June-20-2016 at 12:44pm
So then it only takes 1 bad battery to kill the other.
