Engine loading up?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=39384
Printed Date: November-16-2024 at 1:56pm
Topic: Engine loading up?
Posted By: Peacock
Subject: Engine loading up?
Date Posted: July-19-2016 at 6:09pm
1988 Ski Nautique 351W
Had a strange issue this past weekend teaching children to ski. I do teaching every weekend, this issue just started.
Engine acts like a plug wire breaking, but there isn't one. I know for a fact.
Here's the catch. It only does this when under a load pulling skier out of the water.
However if skier gets up by the second try, it never does it. It's only after 5th or 6th attempt.
To fix it, Got to run wide open for about 30 to 60 seconds. (Carb loading up?)
So thought it might be starving for air, Engine compartment blower is working great.
Thought of engine getting hot and carb loading up or bowling fuel. Engine temp stays between 160 and 180.
Thats about all I got.
Open to others that have experienced this and what you found to be the fix.
Thanks
Posted By: SNobsessed
Date Posted: July-19-2016 at 7:25pm
Have you tried adjusting idle mixture? Also could be needle/seat/float issue. I have had floats fail (not in my boat though).
Posted By: 74SkiNautique
Date Posted: July-19-2016 at 9:16pm
Idle mixture might be too rich and the plugs are fouling until you burn it out.
74SkiNautique
Posted By: baitkiller
Date Posted: July-19-2016 at 9:58pm
Do you run in sea water? I see Carolina's in your avatar. Riser failure will act just as you describe. Pull plugs, check for water , rust, compression.
Posted By: Peacock
Date Posted: July-20-2016 at 10:05am
Only Freshwater.
I'm going back to the water, I will lean it out a little more.
Posted By: Lakeview
Date Posted: July-21-2016 at 10:18am
If your running a Holley,check your power valve inside your front bowl-they tend to fail often.
Lakeview
1992 Barefoot Nautique
1967 Barracuda SS
1967 Chris Craft Cavalier
Date Posted: July-21-2016 at 10:49am
The bilge blower has nothing to do with supplying combustion air to the engine nor keeping the engine cool.
