swap Borge Warner 1::1 from 351pcm to 454pcm
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=39607
Printed Date: October-07-2024 at 6:30am
Topic: swap Borge Warner 1::1 from 351pcm to 454pcm
Posted By: Fire3456
Subject: swap Borge Warner 1::1 from 351pcm to 454pcm
Date Posted: August-07-2016 at 2:41pm
I'm looking at a 86 Supra with a PCM 454 and a Borge Warner 1:1 transmission. The transmission needs work (Not exactly sure what it needs).
I own a good Borge Warner 1:1 tranny out of a 86 Ski Nautique but it was used with a PCM 351.
Will my old B/W 1:1 work in the Supra with a 454? The trannys look alike. But I am assuming the connection/flywheel might be different?
If its possible to swap trannys, what would I need to do so?
Thanks for any help!
------------- 86 2001 Ski Nautique 351w
Posted By: oldcuda
Date Posted: August-07-2016 at 3:14pm
Look at the tags on big block trans probably a 72-c while the one behind the 351. Is more likely a 71-c. 72-c is a bit bigger to handle 454 torque .Yes the 71-c will bolt up but can it handle power?
Posted By: Fire3456
Date Posted: August-07-2016 at 4:00pm
Thanks for the quick response!.
What does the 71c and 72c signify? A more 'rugged' transmission? Where is the C1 or C2 located? i don't see it on my tag. Here are pics of my tranny tag.
Posted By: KENO
Date Posted: August-07-2016 at 4:28pm
Your 10-17 is basically a later version of the 71c
The Supra with a 454 would have a 10-18 which is a later version of the 72c
The difference is that the 10-18 is beefier to handle more torque. It has 2 more forward clutch plates and 2 more clutch discs than the 10-17 and an extra reverse disc too
Overall length of the 10-18 is about than 1 inch longer than the 10-17 and the output couplings are different too 5 inch diameter for the 72c and 4 inch diameter for the 71c
They both have the same 1 to 1 ratio in FWD but in reverse the 72c is 1.1 to 1 and the 71c is 1.0 to 1 which really isn't noticeable but I thought I'd mention it.
I thought of doing this once for the same reason as you and in the end decided it was better to rebuild the 10-18 than try to use the 10-17.to handle that big boy torque of the 454.
And.....there's no e in Borg
KenO
Posted By: Fire3456
Date Posted: August-07-2016 at 5:25pm
How could you tell that my tranny was a 10-17? (was that the number at the top that was worn off leaving what looks like a 17 left?
Being that my 10-17 is an inch shorter, will that effect the shaft placement in the Supra? Since my coupler is 4 inch would I have to use my shaft?
Here was my initial thinking. I thought If I could put my tranny in it for this year and take the 10-18 out and have it rebuilt. (Simple thought for a simple mind!)
I'm taking measurements on the Nautique (shaft length. distance from coupler to boat bottom, etc ...to compare to the Supra)
What did it cost you to rebuild your 10-18?
Thanks Ken!
Posted By: KENO
Date Posted: August-07-2016 at 6:14pm
Thanks Ken!
Yes for the 10-17 number. It would be a 10-17-004.
You can put the 10-18 coupler on the 10-17 (splines should be the same)
The Supra shaft probably couldn't slide an inch forward though without the prop hitting the strut or being too close to get a puller on it if you wanted to remove the prop. The chances of your SN shaft being the right length are.......probably not good but ya never know.
The rebuild was a DIY project, you should look at a manual in the reference section to see what's involved. A few special tools and a couple hundred in parts
Not a complete rebuild per se, but clutch pack replacement since everything else was good. You don't know what's wrong with the one you're looking at so who knows as far as price.
It sounds like you're thinking about buying this boat, so try knocking down the price by a thousand or so, unless it's already good and cheap
KenO
Posted By: Fire3456
Date Posted: August-07-2016 at 6:34pm
Great information. From what I understand my transmission will bold up and I can change out the coupler but the shaft probably isn't long enough to take up the 1 inch difference?
He's asking $2500. The engine runs strong, and only one small rip in one seat. It looks clean inside and out. Well taken care of for an 86.
Posted By: KENO
Date Posted: August-07-2016 at 7:19pm
Fire3456 wrote:
Great information. From what I understand my transmission will bold up and I can change out the coupler but the shaft probably isn't long enough to take up the 1 inch difference? |
Yep but............you're bound to run into unexpected issues that'll cost money to resolve and getting the 10-18 rebuilt would be my choice.
Posted By: Fire3456
Date Posted: August-07-2016 at 7:43pm
Thanks for all the information. It sure saved me time by not trying to get my old tranny to work with the 454. I agree, rebuilding the 10-18 is the best option. Thanks a ton!!!!
