1994 ski nautique engine rebuild help
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=39640
Printed Date: October-07-2024 at 4:26am
Topic: 1994 ski nautique engine rebuild help
Posted By: rrman01
Subject: 1994 ski nautique engine rebuild help
Date Posted: August-10-2016 at 10:52pm
I need some advice rebuilding this 351w pcm pro tech ecm ( carbed) engine. I recently went out for a ride on afternoon and noticed a miss lack of power and smoke coming from the hose I top of the valve cover. At first thought I was thinking clogged pcv valve or inoperable for that matter but upon further inspected of a compression check I doing that the number two cylinder had zero compression and all other cylinders averaged 120. After speaking with a number of people and trying to pinpoint the exact cause I found that the top of the #2 piston was missing a small chunk out of it and it looks as if something had either fallen Into the intake or just old age I'm not too sure yet. This is what I know right now, this engine is from what I understand half way converted from a protech fuel injection to ecm and carb. Since I bought the boat I've wanted to put finish the conversion and buy the kit from ski dim to make it a distributor carb engine and eliminate all possibilities of having problems with the ecm In the future and cleaning up the Intske so it's not cluttered with unused plugged originally meant for the throttle body. I also understand that the carbed version of this engine is a drop In horsepower but since I'm doing the rebuild I'm wondering if I can gain a little in ungrades like maybe a new cam style? This engine has the three bars on the heads which is gt40 and I'm having them gone through and looked at along with the block this week. Is it worth boring out the cylinders? What Pistons and rings should I go with? And other upgrades that might help I have not yet covered would be helpful?
Posted By: rrman01
Date Posted: August-10-2016 at 11:19pm
Posted By: MrMcD
Date Posted: August-11-2016 at 2:32am
That is classic detonation damage. Not unusual at all. The main cause of detonation would be over advanced timing. A lean cylinder could do this also. Intake/pvc air leak or a failing fuel injector but you did say this was carbed. Lean cylinders burn very hot. The extra heat makes the gasoline blow up at the wrong time, way early. Your head gaskets could be damaged also. Crossed spark plug wires or bad spark plug wires that are cross firing is another cause of detonation. Any time the gas ignites too early the piston is trying to go up in the cylinder and the fuel explosion tries to blow that piston back down while you have 7 other cylinders pushing it up. This creates extreme pressure in the cylinder and breaks parts. Detonatation Normal pressure in a wide open 351W might be 600 PSI at the fuel explosion. With detonation that same cylinder can see 3,000 + PSI and that starts breaking parts. The piston ring under that piston fracture is most likely broken also. Since your problem is only one cylinder, check your spark plug wires for Halo's. Small white halos indicate spark jumping through the plug wire. Inspect your intake gaskets very close and measure them to make sure they had even clamping. The leak if you had one would have been at the intake port for that cylinder. Fix the problem before starting the engine again. More than once I have seen guys repair the damage and then repeat the failure because the problem was not fixed. There could be 10 more reasons for that detonation but I listed the most common. Hope it helps.
Posted By: Duane in Indy
Date Posted: August-11-2016 at 6:15am
Speedway Motors sells "Flotek Cylinder Heads" for $740 delivered. 58cc chambers will help up the compression. Weight savings of 40 lbs. If interested then definitely call Tristate Cylinder Heads, as they manufacture them. They will steer you into the correct part #. I would definitely overbore and get rid of the dished out pistons. New cams are available from Comp Cams also. Aluminum intake and Quickfuel carb. HP = $$. The more $$ the more HP You can make a lot more power, but that does not necessarily mean a lot more speed.
Posted By: gun-driver
Date Posted: August-11-2016 at 11:24am
A local highly respected engine builder around here got a set of the Flotec heads to check out. He was not impressed in the least. I don't think you want to hang those heavy cast manifolds on aluminum heads anyway. I can say with experience it takes big$$ to make big ponies. But if your just looking at heads, intake, cam that's not to pricey. You already have a descent set of heads so a cam, intake, carb and a good distributor will get ya smiling for a little over a grand I'd guess.
Date Posted: August-11-2016 at 12:16pm
gun-driver wrote:
A local highly respected engine builder around here got a set of the Flotec heads to check out. He was not impressed in the least. I don't think you want to hang those heavy cast manifolds on aluminum heads anyway. |
Bolted on with the proper length bolt and proper grade bolt and proper torque then there would be no issue.
Using about 4800 rpm for our use, look at the comparison by this independent source. They state best $$ value. You'd be hard pressed to equal $ in GT40P heads or even GT40 IMO and we all know what opinions are worth without data to back it up. http://www.hotrod.com/articles/ccrp-1302-six-budget-ford-heads-that-work/ Duane
Date Posted: August-11-2016 at 12:46pm
Using about 4800 rpm for our use, look at the comparison by this independent source. They state best $$ value. You'd be hard pressed to equal $ in GT40P heads or even GT40 IMO and we all know what opinions are worth without data to back it up. http://www.hotrod.com/articles/ccrp-1302-six-budget-ford-heads-that-work/ Duane |
http://www.hotrod.com/articles/ccrp-1302-six-budget-ford-heads-that-work/" rel="nofollow - Here's the link to Duane's backup to his opinion.
Posted By: MrMcD
Date Posted: August-11-2016 at 1:06pm
When you bump the compression you create the need for Premium Fuel, not always available for Marine use. Buying gas at Marina's many times only offer regular fuel. 85 or 87 octane. You can make more pistons look like the one above quickly. The GT 40 heads can be rebuilt for $400 normally. Don't think I am against horsepower. I am currently building a 406 Chev that should come in around 525 HP and over 500 Ft Pounds of torque with AFR aluminum heads but you need to know there is a trade off when making more power. Some changes allow use of regular fuel and add power, some mean you will need 91 octane or better forever.
Posted By: Dreaming
Date Posted: August-11-2016 at 1:38pm
I'm working through this same motor combination right now. I just did the protect/EFI conversion to carb and DUI distributor. you don't need the ski dim kit, it's more expensive than the DIU performance distributor, and the wiring is really very simple (once I got past the unknown of removing the TBI/EFI wiring) . In my research, I have found that you can get a GT-40 long block from summit racing for ~2300, and after several machine shop calls yesterday, it sounds like machining + parts is going to be in the same neighborhood for me cost wise. it might be worth looking at a long block or short block as a base, unless you really are wanting to do something custom or out of the ordinary. Summit is where I got my DUI also, just add it on at the same time and be done with protec issues .
Posted By: rrman01
Date Posted: August-11-2016 at 10:09pm
this may confirm your theory just a little and i did find that the number two plug wire was burnt from rubbing up against the exhaust manifold. although the local machine shop i took the block and heads too today think something was dropped in the engine. i seriously doubt that had happened but who knows, i didn't find anything in the engine or oil pan so if that was the case it burnt up and melted like the piston.
Posted By: rrman01
Date Posted: August-11-2016 at 10:17pm
I'm going to see that the machine shop says and go from there. aside from getting rid of the pro tech system i basically just want to tweak the engine just a little if possible maybe a dif cam size or an intake but from what I've read the intake is tricky because I'm already maxed on clearance from the engine cover and most after markets are taller..
Posted By: MrMcD
Date Posted: August-12-2016 at 5:42am
Your piston damage is detonation, no question. When a hot spot in the cylinder starts your fuel ignition just before the spark plug ignites you end up with two flame fronts. Two flame fronts will swirl and under compression pressure will form a torch. The torch melted not only your aluminum piston but also the cast iron piston rings. In the right conditions this can happen in only 10 seconds! I have seen holes burned right through between two cylinders. For those that have not seen this issue 200+ times this scenario is exactly why I am always conservative on timing settings. Why did your engine have a hot spot??? I would not start it up again till I had found that answer. Save the bad piston it will be a fun talking point some day.
Posted By: MrMcD
Date Posted: August-12-2016 at 5:53am
More items in your picture. The piston is scuffed (black scratches by the piston pin) This tells you the piston head was very hot at failure. Roll it over and study the inside. The under piston head will be discolored. From excessive heat. Piston head heat will heat the piston pin bosses making the piston skirt scuff by the piston pin like yours did. Now look at the underside of the other 7 pistons. If any or all show heat it will tell you how many were running hot before this failure. Your coolant temp gauge can sit rock solid at 140 while the combustion chamber temps are seeing extreme heat. Find out how many cylinders ran hot and then determine why. I am disappointed your machinist did not know the cause in two seconds after seeing that piston.
Posted By: MrMcD
Date Posted: August-12-2016 at 6:05am
A wire burned would fire to ground and kill the cylinder so it would be cold not hot. Check your wires from the dist to the spark plug . Any place two plug wires touch would be a potential cross fire location. That is where you look for halos.
Posted By: GottaSki
Date Posted: August-12-2016 at 10:31am
I'm suspicious of some malfunction in the protec bank of coils fired that jug early, and wouldn't run your new engine without a proper distributor.
River Rat to Mole
Date Posted: August-12-2016 at 10:59am
Wow I've seen two strokes leaned out and burned down like that. In fact I think I have a cylinder and piston still sitting in the garage that look similar. I would bet that the dimples on the piston top that your shop thinks was caused by something being dropped in was the pieces of piston and rings. Was the electrode/ground strap still on the plug?
Posted By: rrman01
Date Posted: August-13-2016 at 3:37am
So the machine shop called and reported that one head was cracked between the two valves so now it's to plan B. Now I'm looking into buying a long block. With the purchase of new heads there is no way to justify cost wise. Probly gonna go with summit on this one. So with that being soar I have a protech ecm for sale and one head and a block that can be be bored over. I'm really thinking over fitting rid of the Holley 600 and going with the quik fuel 600, that with the distributer and possibly new intake should put over 300 hp
Posted By: Dreaming
Date Posted: August-13-2016 at 9:19pm
I feel your pain :) MrMcD suggested a couple of Spokane companies that I am checking into as well, and there is Michigan Motors, and Rapido marine if any of those are close to your "US" location. summit's website says that the motor I listed in my thread ships "tomorrow", I am not sure if that means that they have one on the shelf, or if their ship date is incorrect. The DUI requires a standard oil pump, not the melling high volume that summit has listed on their ATK build... I have asked the question as to whether I can get a standard Oil pump, or not, but have received no response yet.
Posted By: rrman01
Date Posted: August-13-2016 at 11:46pm
to my knowledge the oil pump won't come on the long block do you can buy which ever oil pump you need too, I thought about using my take off but I'm gonna go new just Becusee its too much of a pain to replace if it goes out. There is a local company here in Houston that sales reman marine engines called thunderbolt, I'm gonna call him Monday and find out more about the exact process and if they actually built the engine or it comes off the shelf from another distributer. They have two companies listed on their website that both sale marine engines. List price they have is 1570.00 with core but I doubt it comes with gt40 heads but I'll just have to wait and see. I'll pay the extra money to have them exchanged. I've been looking into the dui distributor and quik fuel 600 carb to replace my Holley now i just need to figure out the intake. Use original take off or buy aftermarket? They also offer a boil service at thunderbolt to remove paint and Rust from all my old part like water pumps, impeller pumped, bell housing, brackets and so forth to bring back to new so I can repaint to follow my paint scheme of my 94'. I'm thinking of going with dark ford blue and get away from original. Where can I find a oil pan that is this size besides ski dim?
Date Posted: August-14-2016 at 11:44am
What's wrong with the oil pan you have?
Posted By: rrman01
Date Posted: August-14-2016 at 3:14pm
It's has a pretty bad. Rust spot on it and I'm not sure just how bad it is just yet until I get it cleaned up. If it can't be fixed and the metal is too weak I will have to order another one and just want to be prepared,
Posted By: rrman01
Date Posted: August-25-2016 at 11:55pm
progress on rebuild, atk marine long block, gt40p heads.
not sure why the pics turn sideways, how can i fix this
Posted By: Bri892001
Date Posted: August-26-2016 at 12:03am
rrman01 wrote:
... not sure why the pics turn sideways, how can i fix this |
Looking good.
Did you take the pics with an iPhone? Apple has their own funny eco system with the pictures. I researched it once and of course, they claim they are right and everyone else is wrong.
Anyway, either with your phone, or if you save the picture to a computer desktop, just open the picture in an edit mode. Even the most basic editing tools, like "Paint" on a PC, will usually let you rotate a picture in 90 degree increments.
Posted By: Dreaming
Date Posted: August-26-2016 at 2:15am
your a couple of days ahead of me, looking good!... I like the blue and black valve covers! The boil service might have been a good Idea, and much like you said, my oil pump came separate, I didn't realize that they would ship it separate.
Posted By: sport1999
Date Posted: August-26-2016 at 9:32am
Looking good. Really like the valve covers!
Posted By: rrman01
Date Posted: August-31-2016 at 10:36pm
got the engine in the boat finally, did initial start up today and after a few small wiring issues and some minor water leaks in the impeller housing and thermostat we are good to go. carb didnt need any adjustment to start up and once we got the timing set to 10 over it purred. I'm really not liking this stock exhaust housing/muffler. im going to replace it with the y pipe and do away with the it as soon as i can find one. everyone i talk too so far says its 14 days out so I'm assuming centek has to make it. any leads would be appreciated.
Posted By: MrMcD
Date Posted: September-02-2016 at 7:34pm
Congratulations on the install and fire up. If your engine is a roller cam engine it is good to go. If it has flat tappets you need to break the cam in, maybe this was already done but it is absolutely necessary for any flat tappet camshaft. Break in means you take the RPM up to 1,500 -2,500 for the first 20 minutes of run time. This gets your lifters spinning properly and allows them to break into your camshaft. If not broke in this way many flat tappet cams go flat and fail. The engine looks fantastic, nice work. Is your air cleaner Marine approved? It looks much better than the Marine filters I have seen.
Posted By: rrman01
Date Posted: September-02-2016 at 8:47pm
Unfortunately the long block I bought from atk with gt40p heads is an ESeries, it's a non roller with flat tappet. I have ran it for over 30 minutes alternating rpms constantly from 1000 to 2500 and its purrs ans fires up without hesitation. I fired it up cold today and went for a ride and it took less than 1/2 second to star with no throttle. That's nothing I'm used to that's for sure. It's sounds better now than it ever has but after the y pipe install it will be perfect. The K&n marine air filter is good. I never knew k&n offered a Marine filter and housing till I joined this forum so thanks. It's a lot shorter than anything pick offers and we need all the room we can get under the engine cover. I'm still gonna go a few hours just I case to wrap it out on the top end but with Labor Day this weekend we will see shortly I'm sure. end result I wish I would have just bored out the block I had and kept it. I found a set of gt40p heads to put on it that I'm having rebuilt so all these parts I have for sale might go toward another project boat I found. 1998 air
Posted By: MrMcD
Date Posted: September-03-2016 at 11:11pm
If it runs perfect the only danger at this point is getting hot. After the first hour I would not be afraid to open the throttle but I would not keep it there more than a few seconds, less than 15 seconds, should be enough to get some idea how it pulls top end. Running hard heats the internal parts and a new engine will heat far more than a broke in engine so be careful but enjoy it. After the first hour I would ski if I wished but not barefoot yet. Maybe after 5 hours. Be conservative on the timing factory specs are perfect, extra timing makes extra combustion heat. and you don't want that. Enjoy now
Posted By: Jonny Quest
Date Posted: September-04-2016 at 4:31am
Love the QF carb and K&N filter/flame arrestor. Great look.
