Teleflex Steering Cable PN?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=39762
Printed Date: November-16-2024 at 1:41pm
Topic: Teleflex Steering Cable PN?
Posted By: Scrawford
Subject: Teleflex Steering Cable PN?
Date Posted: August-24-2016 at 11:17am
I need the Teleflex steering cable part number for a 1997 ski Nautique. Anyone know what it is?
Eric
97 196 Closed Bow
Posted By: Jonny Quest
Date Posted: August-24-2016 at 7:07pm
1993 to 1997 Ski Nautiques use the same rack & cable.
Go to NautiqueParts.com and search for "S2205-20"    That should be the Teleflex replacement (not the OEM from CC). The Correct Craft OEM cable is $319. The Teleflex replacement cable is $195 and should fit your existing "older style" helm from 1993 to 1997. Or, you can change-out the helm to the newer style and you can use the less expensive newer style steering cable. That is the route that I went. I purchased the new tilt helm - part number 5205 for $76. Then I went with the newer style cable - part number 90590 for $189.
Date Posted: August-24-2016 at 7:39pm
Why did you also change out the helm? Aren't they both the same and pinion?
Eric
97 196 Closed Bow
Date Posted: August-24-2016 at 10:36pm
The older style cable and helm for 1993 to 1997 Nautiques have to be used together. The newer style cable won't bolt up with the older style helm.
I changed to the newer style helm because the newer cable is a better design and is cheaper and easier to get.
Date Posted: August-25-2016 at 1:34pm
Alright, I found the original one I purchased on Amazon Prime. The actual Teleflex PN for the standard replacement is SSC 12420. I put this one in about 6 years ago and it's worked great, it is just now starting to get harder to steer. $135 with free shipping.
Eric
97 196 Closed Bow
