88 Dominique
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=40511
Printed Date: October-07-2024 at 2:27am
Topic: 88 Dominique
Posted By: brettmac
Subject: 88 Dominique
Date Posted: February-08-2017 at 2:37pm
Rebuild starter failed prior to layup, quick question, if the dizzy rotates CCW from the bow, i need a CCW starter correct. Thanks in advance. Regards Brett
Date Posted: February-08-2017 at 2:40pm
Dizzy always rotates CCW on a ford Windsor (regardless of engine rotation ).
Posted By: KENO
Date Posted: February-08-2017 at 3:27pm
brettmac wrote:
Rebuild starter failed prior to layup, quick question, if the dizzy rotates CCW from the bow, i need a CCW starter correct. Thanks in advance. Regards Brett |
Go back and read your previous threads on starter issues, maybe you'll remember what you bought
You need a CCW starter for your PCM 351W RH rotation engine.
ARCO 70101 is a good cross reference number, so is PCM RA122102
ARCO 70201 is the newer style ARCO that will work too with a little extra wiring
Date Posted: February-08-2017 at 3:37pm
brettmac wrote:
Ok, rebuilt starter failed prior to layup last fall, winterized by hand. PIA.
| Brett, What was the failure on the starter? Are you sure there isn't an underlying cause that wasn't addressed? Also, what was the problem with the winterizing? You mention it was a PITA!
