Transmission output shaft bearing grinding......
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=40646
Printed Date: November-16-2024 at 7:40am
Topic: Transmission output shaft bearing grinding......
Posted By: Kodiak
Subject: Transmission output shaft bearing grinding......
Date Posted: March-07-2017 at 10:43am
Just purchased...84 correctcraft...351 ford.....can i replace this bearing?
Date Posted: March-07-2017 at 11:15am
Scott, Are you sure the noise is from the bearing? Have you disconnected the prop shaft as a means of isolating the noise?
Posted By: Kodiak
Date Posted: March-07-2017 at 10:36pm
Not yet...will do.....marbles in a tin can.......
Date Posted: March-08-2017 at 7:55am
Posted By: GottaSki
Date Posted: March-08-2017 at 10:37am
Your not spinning the shaft dry, right?
River Rat to Mole
Date Posted: March-08-2017 at 1:48pm
Scott, Tim brought up your damper plate. That was one of my first thoughts but your title regarding the bearing led me to comment about disconnecting the prop shaft for a better idea of what's going on. Getting back to the damper plate and your saying it sounds like marbles in a tin can, I too feel the plate may be the problem. Is the sound just at idle? If so, what's your idle RPM? When low, harmonics from the engine have a tendency to rattle the planetary gear set. Do you know when the damper was changed last?
