Indirect steering
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=40696
Printed Date: November-16-2024 at 7:36am
Topic: Indirect steering
Posted By: TRIP
Subject: Indirect steering
Date Posted: March-16-2017 at 3:29pm
When driving in a straight line the steering on my '97 Super Sport is super indirect. You have to turn the wheel around I guess 60 degrees before the boat starts turning. As soon as it starts turning it steers fine, so only around the centered position it has this issue.
Any suggestions on what/how to check?
http://www.flyzone-cr.com" rel="nofollow - FlyZone Costa Rica Wakeboarding
http://www.correctcraftfan.com/diaries/details.asp?ID=8406&sort=&pagenum=1" rel="nofollow - 1997 Super Sport
Date Posted: March-16-2017 at 3:37pm
Sander,
First check for play from the helm back. You shouldn't have to turn the wheel that much. If OK or slight, you may consider tuning the rudder. It puts a slight load on the rudder. If you don't have a tunable rudder, filing a bevel on the leading or trailing edge works.
Posted By: quinner
Date Posted: March-16-2017 at 5:15pm
That does sound very strange, have you tried blocking the rudder while on the lift or trailer and then turning the wheel each way to see what is happening??
http://www.correctcraftfan.com/diaries/details.asp?ID=1143" rel="nofollow - Mi Bowt
Posted By: Gary S
Date Posted: March-16-2017 at 5:57pm
Thats because your driving a big old tub it's a Nautique in name only. Seriously though check where your steering cable mounts to the back stringer,Quinner's neighbor's SS the bolt pulled out of the stringer and was loose. Stripped the aluminum backing plate, I believe he was able to drill and tap next size up.
Posted By: tryathlete
Date Posted: March-16-2017 at 7:27pm
That is correct, Gary. I went with a big stainless steel lag bolt and it is never coming loose again.. I am betting this is your problem.
Posted By: TRIP
Date Posted: March-16-2017 at 9:27pm
Thanks guys, gonna check this weekend if time allows.
Date Posted: March-16-2017 at 10:27pm
Try to bring someone with to move the steering wheel
While you are at the rudder linkage. It's either loose back there or possibly the helm is worn. Sometimes people keep steering with a worn cable and it really wreaks havoc on the fragile aluminum worm gear and rack.
Let us know what you find. We all like to help and solve this stuff.
