79 Mustang, missing carb jets
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=40704
Printed Date: November-16-2024 at 8:39am
Topic: 79 Mustang, missing carb jets
Posted By: KooK
Subject: 79 Mustang, missing carb jets
Date Posted: March-19-2017 at 3:03pm
http://documents.holley.com/techlibrary_4150_4160_exploded_view.pdf
Part 118, I tore my carb down and somebody never put these hogs back in. Might explain the over-fueling issue I was having last season. Does anybody know what size these are stock in the 7159?
Posted By: KooK
Date Posted: March-19-2017 at 3:06pm
Also, what does everybody do for the dry float settings? The instructions in the rebuild kit leave them out completely
Posted By: KENO
Date Posted: March-19-2017 at 6:56pm
Stock jets for a list 7159 carb are #59
When you have the bowl upside down in your hand, the top of the float should be parallel to the top of the bowl as a starting point Here's a picture, just remember the bowl is upside down so the top is on the bottom
You may have to adjust the float level to be a little lower, then again you might not
In this picture, borrowed from some old post here on CCF, the float isn't quite parallel with the top of the bowl so the float level is a little lower.
If you ask a dozen people, 6 will say adjust it parallel and the other 6 will say slightly lower due to the engine mounting angle.
