Gauges act funny when lights are on?z
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=4078
Printed Date: September-27-2024 at 8:48am
Topic: Gauges act funny when lights are on?z
Posted By: Brewski*
Subject: Gauges act funny when lights are on?z
Date Posted: July-05-2006 at 10:16pm
I have only had my 89 out a couple of times at night and never noticed this before but when I turn the lights on make that Only when I turn on the full navagation lights the temp gauge goes up and the voltage gauge drops to 11V and the gas gauge flucutates alot more than normal and reads less gas. What is going on?
Date Posted: July-06-2006 at 9:30am
Our boats suffer from inadequate wiring to the dash. All the gauges are daisy-chained together with only one small guage wire for power and one for ground feeding all of them. Run some thicker wires up to the dash and it should solve the problem.
Posted By: 79nautique
Date Posted: July-06-2006 at 10:03am
clean the leads and make sure the belt is tight on the alternator. You should not be able to spin the fan on the alternator if the belt is proberly tightened
Posted By: David F
Date Posted: July-06-2006 at 12:03pm
Yes, what 79.. said. And especially pay attention to the grounds as this is what is daisy chained from instrument to instrument and usually the cause of the proplems, IMHO.
Posted By: Jim_In_Houston
Date Posted: July-06-2006 at 3:47pm
What 79 said....
------------- Happy owner of a '66 and a '68 Mustang
Posted By: 64 Skier
Date Posted: July-11-2006 at 8:37am
Had a similar problem or reduced voltage when starting. Ran down a loose connection in the "daisy chain" and it solved the problem.
------------- 64 Skier
66" HO VTX and 67" HO Triumph
http://www.correctcraftfan.com/diaries/details.asp?ID=1071&sort=&pagenum=3&yrstart=1971&yrend=1975 - 71CC
Posted By: 1970 Mustang
Date Posted: July-11-2006 at 1:28pm
It is also a good idea to disconnect those rusted/loose ground connections and hit them with a wire brush. More metal to metal contact is always better than rust for electrical connections.
