2002 GT 40 Long Block
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=41020
Printed Date: October-07-2024 at 12:29am
Topic: 2002 GT 40 Long Block
Posted By: compskier
Subject: 2002 GT 40 Long Block
Date Posted: May-05-2017 at 5:02pm
I'm looking to put a long block GT 40 engine in my 2002 Ski Nautique and have 2 questions:
1. I'm getting conflicting info on the engine rotation. One says that it requires a reverse rotation engine and another source says standard rotation since it has the 1.23/1 transmission. Both are people that are knowledgeable on Correct Crafts and I respect their experience, but I don't know which way to go. How do I get a definitive answer? 2. I've been told that if the engine has been rebuilt, it can't be bored more than 20 thousands (0.020) or the computer will run the engine too lean. Is this correct?
Thanks for any insight, first time posting on this forum. Ed
Posted By: KENO
Date Posted: May-05-2017 at 5:14pm
Thanks for any insight, first time posting on this forum. Ed |
Your definitive answer would be the ID tag attached to the intake manifold if it's still there or you could look at your firing order as another check (looking at the distributor a normal rotation is 1 3 7 2 6 5 4 8 going counterclockwise) reverse would be 1 8 4 5 6 2 7 3 also going counterclockwise) or you could listen to the second answer somebody gave you about it being normal rotation since it's a CC and it's hooked to a 1.23 to 1 transmission
As far as the second question, I seem to remember hearing something like this, but can,t imagine it's tuned that close to the ragged edge as a stock engine and that the 0.020 or a 0.030 or 0.040 overbore would really matter...................but don't believe me on that, wait for more answers.
Posted By: Gary S
Date Posted: May-05-2017 at 5:19pm
Some of the newer motors have the engine number on a decal now either on the valve cover or on the bel housing cover plate. And yes it's normal left hand rotation. Have heard the same on over bore but no actual confirmation
Posted By: KENO
Date Posted: May-05-2017 at 6:11pm
This might be what me and Gary are remembering. It's from Planet Nautique
https://www.planetnautique.com/vb5/forum/nautique-topics/maintenance-technical-discussion/15030-lessons-learned-on-the-efi-gt-40" rel="nofollow - PN thread about overbore
Fair amount of conflicting info between posts so no definitive answer there.
I'd talk to Jody Seal at Florida Inboards I think and see what he says
http://www.floridainboards.com/contact-us.html" rel="nofollow - Florida Inboards
After reading it a few times it sounds like bad sensors caused his problem after the rebuild and once they were replaced the ECM handled his 0.040 overbore with no problem.
Posted By: Jonny Quest
Date Posted: May-05-2017 at 6:46pm
The 1.23:1 transmission is a reducing, reversing transmission, so look at the propeller. If you have a right hand prop, then you have a standard rotation engine. I believe that the GT 40 is only standard rotation.
A R-R engine in 2002 would be very rare.
Posted By: gun-driver
Date Posted: May-05-2017 at 8:44pm
Compskier you need to find more knowledgable group because the GT-40 is a lefty only.
Date Posted: May-05-2017 at 9:17pm
Ed, How about some pictures of the boat when you get a chance? Welcome to posting as well as CCfan.
compskier wrote:
. I'm getting conflicting info on the engine rotation. One says that it requires a reverse rotation engine and another source says standard rotation since it has the 1.23/1 transmission. Both are people that are knowledgeable on Correct Crafts Ed | Well, one is not knowledgeable! I'd stay away from him!
Posted By: Orlando76
Date Posted: May-05-2017 at 10:03pm
Where in FL are you?
------------- Please support The Cystic Fibrosis Foundation 1976 Ski Nautique 351 Escort 1993 Ski Nautique purple and black 351 HO PCM
Posted By: KENO
Date Posted: May-06-2017 at 12:42am
Hi Ed
Check your PM Inbox
Posted By: malibud
Date Posted: May-07-2017 at 9:05am
Yes on over bore. It's been a while but I was in the same boat with cracked block . I called pcm if I rembered correctly they said not to go over xxx because the ecu could not compensate .
