Strange starting problem
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=4119
Printed Date: November-27-2024 at 2:37pm
Topic: Strange starting problem
Posted By: THutchins
Subject: Strange starting problem
Date Posted: July-09-2006 at 12:19pm
Here's a strange one, Have a '65 Barracuda w/ 318. New Edelbrock 1409 600cfm carb. Was idling great and ran well (some minor rough spots). Noticed that the water line to the Trans cooler was a little firm, so I disconnected it from the cooler and sure enough there was a bunch of pieces of impeller stuffed in there. Emptied it out and pumps great now. Unfortunately I can't get it to idle now. It starts with some throttle and runs at about 1200 rpm but if I put in idle it dies immediately, doesn't matter if warm or cold. Doesn't start at idle but fires immediately if given throttle then dies if put at idle. What the heck did I do by clearing the cooling hose to the trans cooler?
Any ideas?
thutch
Posted By: 77stang
Date Posted: July-09-2006 at 1:52pm
coincidence
------------- http://correctcraftfan.com/diaries/details.asp?ID=1360&yrstart=1971&yrend=1975 - '77 Mustang 17
Date Posted: July-09-2006 at 2:36pm
That's possible, though I can't imagine what could go wrong in a matter of 5 minutes sitting at the dock not rumnning. So what do you think the cause of the problem staying started at idle is? New carb, new feul pump etc. Do I need to readjust the carb? Starting from the choke and idle etc?
Date Posted: July-09-2006 at 4:46pm
Well, retuning the idle screws seems to have done the trick.
Posted By: care2jen
Date Posted: September-04-2006 at 11:36pm
how do you retune idle screws?
------------- j. halteman
Posted By: care2jen
Date Posted: September-04-2006 at 11:42pm
how do you set choke to be automatic? i am manually doing it now & would like any input on how to fix this problem.
