starter issue
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=41384
Printed Date: October-06-2024 at 10:16pm
Topic: starter issue
Posted By: brettmac
Subject: starter issue
Date Posted: June-29-2017 at 10:44am
Replaced the starter on the 88 Dominique and the bendix is not engaging the flywheel. Makes a crunching noise, but the motor isnt turning over or moving. Motor turns easily with a socket. What should i be looking at? Starting to think with all of the starter issues ive had that there is something else wrong. Any suggestions wuld be helpful. Thanks. Brett in WNY.
Date Posted: June-29-2017 at 11:30am
Brett, Where did you get the new starter? Do you still have the old one or did you turn it in for the core? If you still have it, pull the new and compare the nose with the old.
Posted By: GottaSki
Date Posted: June-29-2017 at 11:31am
Actually, knowing the hull type is of little use to the solution
have you inspected the bendix yet?
River Rat to Mole
Posted By: brettmac
Date Posted: June-29-2017 at 11:48am
Will be pulling and comparing to the old one tonight after work.
Posted By: scootdogydog
Date Posted: June-29-2017 at 11:51am
when you compare them, take pictures and post them along with the part numbers...someone will be able to help you (not me though)
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=7183" rel="nofollow - 1999 Python 1980 Ski Tique 1968 Mustang WIP
Posted By: KENO
Date Posted: June-29-2017 at 11:54am
Here's a link to your http://correctcraftfan.com/forum/forum_posts.asp?TID=40511&KW=&title=88-dominique" rel="nofollow - old thread with part numbers for what would work.
Those numbers (Arco 70101, 70201) have the right nose depth of 2 3/8 inches for your engine and rotate the engine the right way for your RH engine
The RH engine rotation was figured out in previous threads/posts
