MAP sensor and TPS GT 40
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=41393
Printed Date: November-16-2024 at 3:40am
Topic: MAP sensor and TPS GT 40
Posted By: workky
Subject: MAP sensor and TPS GT 40
Date Posted: June-30-2017 at 2:05pm
Does anyone have a part number for the TPS and map sensor I prefer Motorcraft Parts if possible, or motorcraft PN's I have looked through the GT-40 spreadsheet and dont see any listed
I need to try and pick these up today I would just go to the boat and pull them,but its 1 hour away
Thanks for any help
Posted By: Bri892001
Date Posted: June-30-2017 at 3:11pm
Nautiqueparts has the MAP sensor: https://www.nautiqueparts.com/product/map-sensor-pcm-gt40/" rel="nofollow - https://www.nautiqueparts.com/product/map-sensor-pcm-gt40/
Does the GT-40 even have a Throttle Position Sensor? It's still a mechanically operated throttle body, so I'm not sure if a TPS is in the mix or not. Someone more knowledgeable than me can hopefully answer that. Both Skidim and Nautiquparts have GM TPS's but none for the GT-40.
Posted By: fgroce
Date Posted: June-30-2017 at 5:00pm
Hi Ford used several different plugs on the ends of the TPS. One from a 94 Ford 150 or a 96 F150 with a 5.8 may fit, each has a different end on it. The only way to know for sure is if someone has a part number.
------------- FGroce 88 Ski Nautique For 28 years Now 2002 Ski Nautique
Posted By: workky
Date Posted: June-30-2017 at 5:08pm
I'm not sure about your boat, but ours defiantly has a TPS sensor on top of the throttle body
Posted By: lewy2001
Date Posted: June-30-2017 at 11:12pm
The base number for the TPS is 9B989 they vary depending on wiring loom. Let me check but the picture for the E4TZ-9B989 looks to have correct wiring connector.
