low oil alarm
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=41458
Printed Date: November-16-2024 at 3:51am
Topic: low oil alarm
Posted By: chris777
Subject: low oil alarm
Date Posted: July-08-2017 at 5:07am
On my 2003 216 air nautique the low oil pressure alarm goes off as soon as I start the engine.Then after a few seconds it's gone. The boat is totally fine after that. Is the brief time the alarm is on a indicator of something worse? What should I do about it?
Date Posted: July-08-2017 at 6:23am
Jim, Sounds like the alarm is doing it's job. Before the engine runs for those couple of seconds, there isn't any oil pressure. Welcome to CCfan.
Posted By: chris777
Date Posted: July-08-2017 at 12:15pm
We've taken it to the boat mechanic and he has ran it and has replaced the oil pressure valve . No codes appeared on the computer. He told us to run it and watch it? Anybody else have a similar problem and how did you fix it?
Date Posted: July-08-2017 at 12:19pm
chris777 wrote:
We've taken it to the boat mechanic and he has ran it and has replaced the oil pressure valve . | The pressure relief valve? Wow, that's a big job.
Posted By: chris777
Date Posted: July-08-2017 at 12:22pm
The oil pressure valve that's on the side of the engine is the thing he replaced. It was an easy thing to to do.
Date Posted: July-08-2017 at 12:31pm
chris777 wrote:
The oil pressure valve that's on the side of the engine is the thing he replaced. It was an easy thing to to do. | Now that's easier. That's the pressure sender and not the pressure valve. What was the pressure gauge telling you?
Posted By: chris777
Date Posted: July-08-2017 at 1:17pm
The pressure gauge took a couple seconds to read normal and after that it was fine. Since we changed it, it only flashes once. Its alarm goes off for a much shorter period of time.
