Casting plug replacement trick
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=41553
Printed Date: October-06-2024 at 10:25pm
Topic: Casting plug replacement trick
Posted By: ceruzziracing
Subject: Casting plug replacement trick
Date Posted: July-19-2017 at 6:52am
I had been scratching my head trying to figure a way to get to the four casting plugs behind the engine mounts w/o having to pull/lift motor. Finally came up with a solution that worked for me on my '97 176. Photo may be hard to decipher but this is what I did. Prepped the openings per usual with sandpaper and ran film of Permatex around inner edge. Placed new plug in block and, using an old plug and small pry bar, pressed the new plug in using engine mount for leverage. Had the old plug with concave surface facing block and levered new plug into seat. Takes some trial and error, and would be great to have smaller hands lol.
Posted By: SNobsessed
Date Posted: July-19-2017 at 8:57am
Great tip!
Where there s a will, there's a way.
Posted By: GottaSki
Date Posted: July-19-2017 at 10:39am
Tenacity is a virtue, well done
However, wedge a smartly cut 2/4 under the exhaust manifold to take the pressure off, one can take the mount right off.
River Rat to Mole
Posted By: 75 Tique
Date Posted: July-19-2017 at 10:51am
Does this work for freeze plugs, too?
Posted By: KENO
Date Posted: July-19-2017 at 11:14am
Don't worry Larry, Pete will come along with the answer
Date Posted: July-19-2017 at 11:34am
KENO wrote:
Don't worry Larry, Pete will come along with the answer | Ken, I trust Larry's intelligence to be able to figure this one out by himself. He certainly doesn't need me to confuse the issue!
Posted By: WinterTurtle
Date Posted: July-19-2017 at 11:37am
Good to know it's possible! I have a 10+ year old dry rubber stopper I need to replace with one behind the starter. No idea how accessible (or not) it is but surely an adventure!
Posted By: KENO
Date Posted: July-19-2017 at 11:43am
8122pbrainard wrote:
KENO wrote:
Don't worry Larry, Pete will come along with the answer | Ken, I trust Larry's intelligence to be able to figure this one out by himself. He certainly doesn't need me to confuse the issue! |
Good answer Pete
Posted By: Dreaming
Date Posted: July-19-2017 at 2:03pm
just pull the starter... its two bolts and a couple of nuts for the wires. Pulling the starter will save you an hour of futzing to get the two plugs to line up correctly so you can lever the plug in using something you shouldn't pry on
Date Posted: July-19-2017 at 3:30pm
Or in the case of that one, you could utilize a proper casting plug insertion tool. That way you don't lever against anything and concern anyone.... They run about $75 online
Date Posted: July-19-2017 at 3:31pm
Maybe unhook battery 1st, then pull starter. I bet someone has done that backwards & had a few sparks!
