Fuel Pumps and In-line fuse
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=41590
Printed Date: October-06-2024 at 10:16pm
Topic: Fuel Pumps and In-line fuse
Posted By: wdg8769
Subject: Fuel Pumps and In-line fuse
Date Posted: July-23-2017 at 3:02pm
95 Ski Nautique - GT40
After having intermittent problems with my fuel pumps not priming at start (HP and LP) and engine shutting down while underway, I think i found the culprit with the in-line fuse in the battery compartment. Just a little wiggle on that line while turning the key and the pumps magically prime and engine starts fine. Any advise on replacing that fuse / line or location where can purchase a new assembly? Have read this fuse is responsible for many problems in the early GT40 engine and curious if anyone has done a retrofit to the revised config in later GT40's
Also my engine does not have the FCC and curious if anyone has purchased a turn-key key kit to convert the 95 GT40 to FCC. Replaced the HP fuel pump in '10 but looks like that pump is not available any longer if I have a problem.
Thank you!
Posted By: Gary S
Date Posted: July-23-2017 at 4:44pm
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=25723&KW=&title=gt40-retrofit-computer-power" rel="nofollow - Here is the thread that lewey put together on this fuse. Problem is photobucket has messed with his pic's. You'd have to do a search but someone just this spring bought the conversion kit.
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=41161&PID=530211&title=fcc-retrofit-conversion-for-a-95-sn" rel="nofollow - Found it here it is
Posted By: tnplicky
Date Posted: July-23-2017 at 5:59pm
I did the FCC Conversion on my 1995 in June which I purchased from Discount Inboard Marine (skidim.com). Gary posted the link above. It may not be the cheapest alternative out there (some have retro-fitted other fuel pumps), but I am glad I did it. I haven't had any issues since I replaced with the FCC kit. If you decide to go that route and want some tips, send me your contact info in private message and I will get a hold of you directly.
-Tim
