Need gauges for 1982 sn 2001
Category: Buy and Sell
Forum Name: Boat Parts Wanted
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=41603
Printed Date: November-16-2024 at 12:28pm
Topic: Need gauges for 1982 sn 2001
Posted By: ryans82nautique
Subject: Need gauges for 1982 sn 2001
Date Posted: July-24-2017 at 5:17pm
Hello, I am looking for a gauge set for a 1982 ski nautique. Mainly need the (volt, oil pressure, temp) everything but the speedo's pretty much.
Ryan
1982 Nautique 2001
1984 Carver 3607 Yacht
1999 SAN (8.2L Python) SOLD
Posted By: Kevin's '79
Date Posted: July-24-2017 at 5:43pm
Ryan,
I think I may have some if not all of what you need. I'll look when I get home and try to take some pictures for you.
Kevin
http://correctcraftfan.com/diaries/details.asp?ID=2575&yrstart=1991&yrend=1995 - My '97 SN
Date Posted: July-24-2017 at 5:55pm
Awesome, let me know, I'm headed to work on her tonight, I'll confirm Exactly which ones I need as well.
Thanks,
Ryan
1982 Nautique 2001
Date Posted: July-25-2017 at 2:53pm
I have a voltage, temperature, and oil pressure. You can send me a text to 256-412-8540 and mention gauges and I will send you some pictures back.
Date Posted: July-26-2017 at 10:44am
I have a volt, temp, and oil gauge. The only difference from the originals is the bezel has a silver stripe around it. It might could be removed or the bezel repainted.
All 3 gauges have been tested and work.
Date Posted: July-31-2017 at 4:06pm
I did some more searching and it appears that the gauges I have were used from '76-'79. The only thing different about them is the silver stripe around the bezel. All of these have been tested and the gauge and light works. Anyone else out there need any of these?   If I'm wrong, then please correct me.
Date Posted: July-31-2017 at 5:09pm
Close but not quite. Years look approx correct (have seen them used on a '80 tique and the newer one used on a 79 Bfn) but the differences extend beyond the bezels (which are actually the same- none originally had the silver ring that is commonly found on the NOS gauges). 80-84 gauges have blue dots to mark the increments instead of the lines. Similar but different.
Posted By: scootdogydog
Date Posted: July-31-2017 at 5:20pm
my 1980 ski tique has the dash style pictured above...with a black ring. I thought in '80 the dash and dot style were used interchangeably.
http://www.correctcraftfan.com/diaries/details.asp?ID=7183" rel="nofollow - 1999 Python
1980 Ski Tique
1968 Mustang WIP
