cel- oil pressure
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=41617
Printed Date: October-06-2024 at 10:18pm
Topic: cel- oil pressure
Posted By: harriss28
Subject: cel- oil pressure
Date Posted: July-26-2017 at 7:00pm
The CEL is coming on in my 97 gt-40. I knew it was either the temp switch or the pressure switch. I unhooked the oil pressure sender(the bigger one, with the blue wire), The CEL didn't come back on and the oil pressure gauge stopped working.
I should have disconnected the oil pressure switch though. Why did the CEL stop lighting when I unhooked the wrong sensor?
My thoughts, 1. I need a new switch 2. could the problem stem from running shell rotella T as opposed to straight 40w(lower oil pressures) 3. oil level might be a bit high
Did I read somewhere there is a lower pressure switch that may better suit my situation since Im running multi viscosity oil now?
thanks Shawn
Date Posted: July-26-2017 at 8:03pm
I suggest installing a pressure gauge to get the true oil pressure.
Posted By: fanofccfan
Date Posted: July-27-2017 at 9:23am
I doubt it's the oil type. Many have run the rotella including myself without issue.
------------- 2004 196 LE Ski 1969 Marauder 19 1978 Ski
Posted By: lewy2001
Date Posted: July-27-2017 at 11:40pm
The oil pressure gauge sender and the CEL switch are 2 separate entities on the GT40. It is actually has a different acronym SLOW
Speed Limiting Operational Warning
